Results 1 to 10 of 13
Thread: A dac that works as pre amp?
    I'm Andre.
    Default A dac that works as pre amp?
    Looking for a dac that will work good as a pre also. Need 2 optical inputs, coax and usb from computer - and it has to be able to play MQA from Tidal. I don't need analog inputs and phono input.
    Another concern is that I should magnify the signal like a traditional pre amp. Beresford or even my current Marantz HD-DAC1 don't really have enough signal out to drive my power amp enough even with volume at max.
    Marantz HD-DAC1 -> Pro-Ject Pre Box S2 Analogue -> Hitachi HMA-8500 Mk II -> JBL Balboa 30
    What's the power amp and what's the budget for the DAC?
    I'm Andre.
    The power amp is Hitachi HMA-8500 Mk II (rca input 47 kΩ, 1 V RMS).
    Don't really have a budget. But let's say up to £ 1000 maybe.
    1V is pretty standard. Any DAC with digital volume control should be okay then. Needing 2 optical inputs and MQA decoding narrows down the options quite a bit though.
    I'm Rockabilly.
    Default M-DAC plus Node2i would do it, perhaps?
    The Meridian Ultra DAC has everything that you desire.
    And so it should because it costs more than a new Ford Fiesta.
    The Mytek Liberty DAC can juggle with MQA and has all of your input requirements bar one.
    I can't comment on the pre-amp quality.
    The audiolab M-DAC has all of your input specifications and has a good pre-amp section.
    It will not digest MQA.
    However, you could use a BlueSound Node 2i to decode Tidal with MQA and feed this into the M-DAC.
    (The maximum resolution/sample rate in this case will be 24bit/96kHz.)
    This will be around your budget limit if you buy new - but you can pick these up second-hand readily.
    Johnny Dodgem.
    Cartridges vintage MMs including Pickering xsv-4000/xsv-3000 : Stanton 881s/D81 : AT140LC/VMN40ML
    Spinners hot rod 1210 (Jelco 750D, Origami, Ammonite, Longdog, Vantage, Achromats) : Pye G63 & Garrard AT6 : Two full custom Lencos : Kenwood KD-650D
    Streaming Qobuz : BluOS & Node2 (Fidelity Audio modified) : RME ADI-2 DAC
    Pre-amps Tron Seven (GT modified) : Conrad Johnson EV1 : Croft Micro 25 : Decware ZStage
    Power Amps PrimaLuna ProLogue 5 (KT120) : PrimaLuna ProLogue 4 (KT77)
    Speakers The Edingdale : Meadowlark Hot Rod Shearwater
    I'm Martyn.
    I'm no great expert but my Beresford Caiman SEG/Dorado II runs into a Mission 777BU and drives as loud as anyone could need in a residential setting.
    Even when SWMBO goes out and I have a Black Sabbath moment (got to be done!) I've still never had the volume beyond 50%
    Sent from my motorola one using Tapatalk
    I'm Andre.
    @ Poldark; I agree - I have no problem getting decent volume levels close to max with the dac alone. The Marantz HD-DAC1 dac I have put out 2,3V RMS maximum. But I found I get a much more smooth volume sweep by using the fixed output on the dac and adding a separate pre amp in between the dac and power amp. The sound also sound more full and lively at low volume levels this way. I solved this with a simple chinese made pre that is based of the legendary Marantz SC-7S2 pre amp circuit. One input, one output and a volume controll.
    It looks and feels very well made with Elna and Nichicon caps + Alps volume pot. The left and right amplifier circuits are independent of the line. Power filter with 10000UF*2+ voltage regulator, transformer with full sealed shield potting.
    This is a great combination, and it sounds fantastic to my ears. But now I am considering using this dac and pre amp in a different setup, and therefore on the lookout for a new "all in one" dac/pre combination that also can get me into the MQA world.
    Maybe the NAD C658 would be the solution?
    Quote Originally Posted by Sabaselfsit View Post
    It ticks all your boxes. The DAC is not state of the art but I wouldn't worry about that. You get DIRAC too.
    I'm Andre.
    Thanks guys for your different input. Came to a conclusion and have just ordered the Teac NT-505. It has 2 optical inputs (one 'normal' at the back and a Mini Toslink-Toslink on the front panel), coax, bluetooh and usb + MQA decoder. It's also supposed to be a good pre amp with up to 6v RMS out on rca (just what I was looking for).
    I'm Rockabilly.
    Hi Andre,
    Why did you choose the Teac over the NAD?
    Just curious!
    Johnny Dodgem.
