Results 11 to 20 of 40
Thread: Idiot Question
    I'm Neil.
    Hills Components make a cable which comes in a blue jacket with no plugs as such, as the metal work is bonded into the end of the cable jacket which widens to accommodate it.
    Shockingly good for a few quid imho/e but like most cheap cables not without some issues.
    link to it http://www.hillscomponents.com/product.asp?PROD=21-7389
    Regards D S D L
    Regards Neil
    Strangely enough, or not, I've always found thinner cables to sound better than any of the 'hosepipe' variety, which usually sound phat and bloated in comparison.
    In terms of speaker cable, I've just bought this Van Damme pro stuff from Mark Grant, to use with my Celestions in the lounge, and it's very good indeed at a mind-blowingly expensive (not) £1.90 a metre (!):
    http://markgrantcables.co.uk/shop/in...roducts_id=169
    P.S Andy, could you do me a favour and add your location details to your profile? Cheers!
    I tried DNM I/C as it is similar to the Cyrus cables in construction - thin wires parallel insulation. Then I tried Mark Grant Canare cables and the DNM is sitting somewhere awaiting a fate. Unlike Ali Tait I found the DNM light in the bass area compared to conventional cabling and MG in particular.
    I'm Andy.
    Brought some more to try as speaker cable, will report back, l am still shocked how good this cable is, anybody gonna give it a try( just so l know l am not going mad)
    Me so horny- Impulse H6 Horny
    I'm inthescottishmafia.
    I'm using statics though.It may be a different story on conventional speakers.
    Ali, I'd have thought that if a cable was bass-light you'd know about it more using statics than conventional speakers!
    Also a fan of solid core wire. Even my interconnects are solid core. I've tried various types, braided, silver-plated whatnot, and while sometimes they seemed to perform better in the end it seemed to come from an extra brightness or "edge enhancement" or something that would normally not be there in the music. I started to feel the solid cores just had a more reliable, easy sound, if that makes sense.
    Right now I'm using a very plain Audio-Technica AT-ES1400. Those ones from Mark look interesting too, Marco.
    James
    Denon DCD-755AE (Power supply mods, used as a transport)
    PS Audio Digital Link III (Power supply mods, Audiocom Superclock 4)
    Tricorp TRV-35SE (V-Cap Teflon and Wima MKP10 caps)
    KEF IQ5 (Bennic XPP caps and Jantzen MOX resistors)
    Yamaha YST-SW225 subwoofer
    Cables: Transparent Premium Powerlink, PS Audio xStream Prelude, Mark Grant DSP 2.5, Audioquest King Kobra, Audiotrak Glass Black
    Not really,statics are an easy load in the bass,and drop impedance in the treble.It's generally the opposite for conventional speakers.
    Yup, but what I meant was that, in general, statics (not yours) can be somewhat lacking in (genuine) bass extension compared to the best box speakers in that respect, despite their unquestionable talents in other areas.
    This has certainly been my own experience to date with statics, in comparison to, say, large Tannoys, and so a bass-light speaker cable (if it were genuinely bass-light) used with them would exacerbate that effect more....
    What I was getting at is that because statics generally are an easier load in the bass than in the treble,they would demand less current than conventional speakers to reproduce those frequencies.At least,that's the way it seems to me,I may be completely wrong.In any case,coming from your large Tannoys,you'd no doubt find my statics bass-light by comparison.It's not an issue for me personally,I'm happy to trade a bit of extension for a cleaner reproduction,though being such large panels,they do give a pretty good response.The lack of a box adding to the impression of deep bass can also make statics appear to be more bass-light than they actually are.Most folk are used to the sound of bass from a box,coloured as it is.
