Had a look around and found there is a successor to the Sheevaplug called the Guruplug,more flexible so have bought one.Only problem is the 4 week waiting list.See here-
http://www.globalscaletechnologies.c...rver-plus.aspx
Looks to be a good way to go Ali - they've upped the spec from the Sheevaplug.
You should be able to get it to boot from SD, and also put SBS 7.5.1 onto the same SD card.
Looks like a long phone call to Lurcher might be in order
Chris
Common sense isn't anymore!
Aye!
There is something on slimforums about installing sbs on a sheeva,I'll give it a try myself first.
Learn Linux in the school of many kicks in the nuts ?
Chris
Well I've got a month to learn!
From what I can find out the Sheeva/Guru plug is powerful enough to cope with everything that SBS 7.5.1 can throw at it except for SOX resampling - apparently it can do the resampling, but it's not fast enough to perform the task in real time.
Essentially this means that it can transcode 24/192 files to 24/96 (the fastest the Touch can handle natively), but the tracks will play back at half speed.
Other than that it handles the task of running SBS superbly well.
Chris
Not a problem then,since I don't have any 24/192.
