Hello dac gurus! I have a DL3 dac that I'm looking to tinker around with. My goal is to be able to do is crank the bejezzus out of it without the ear bleed syndrome. I must have girl ears or something because I'm really sensitive to harshness. So I want to start with the dac since I am using multiple sources. Eventually everything will get attention, but it will take some time.
My thoughts are to incorporate some of the mods that the mod houses like Cullen and RAM are doing but maybe using different parts, as well as some other ideas you guys might have. I have no doubt their work would sound better than anything I could accomplish, but the shipping from Japan to US and back would cost more than the sum of all the parts I'd need to do it myself, and I'm a tightwad. That and I'm addicted to filling my pea brain with any bits and bytes I can get a hold of. I'm thinking as long as I'm not using other's ideas to make a profit nobody's gonna get upset. This is just for my own personal enjoyment and I have little ego about it.
But since I'm new to DIY audio I need a lot guidance as to what areas I need to focus on, and which are a complete waste of time. So far I have increased the power supply caps from 48,000uF to 115,000uF with a decent effect of tidying up the sound a bit (the 48,000uF went into my transport). I've also ordered a Audiocom Superclock4 to replace the 27MHz crystal feeding the PLL chip and hopefully I'll get that in a couple more weeks or so. We'll see if it helps the PLL chip do it's job. Cullen and RAM seem to disagree on this.
So, I'll have a bunch of questions I'm hoping you guys can help me out with.
QUESTION#1
According the PS Audio the DL3 uses a discrete output stage but there is an opamp employed apparently to eliminate feedback issues. All this is over my head. This is a snip from the PS Audio website:
<snip>
99% of every DAC on the planet uses an op-amp to convert the output of the DAC to a voltage. We learned years ago that this is the worst thing you can do for the sound, because op-amps all have two major problems when used for this function: feedback and speed issues.
Without getting too technical, the greatest opportunity for a bright and edgy “digital” sound is caused by op-amp based current to voltage converters (IV converters) because the high speed of the DAC’s output causes transient or slewing induced distortion in the op-amps (SID). SID is a combination of feedback and transient response issues that some exotic high-speed op amps can come close to handling, but all have a problem with it.
PS Audio’s engineers avoid the SID harshness by eliminating the feedback of the IV stage. We do this by a unique single transistor IV converter with no feedback. Speed issues and SID issues are completely eliminated with this technique.
</snip>
The part is a "Texas Instruments TL082C JFET Input Operational Amplifier". Whitepaper is here:
http://focus.ti.com/lit/ds/symlink/tl081a.pdf
Do you think there would be any improvements to be had by changing it out for an "exotic high-speed op-amp"? Any recommendations?
QUESTION#2
In the Cullen Mod there are 2 caps connected to this op-amp. From what I can tell, they seem connected to these holes that already exist on the PCB which connect to: pin 3(1 IN+), pin 4(VCC-), pin 5(2 IN+), and pin 8(VCC+). I could be mistaken though. What are the purpose and recommended values of these caps?
Also what do you think of the Dale resistors? Any other recommendations? I like detail, but not so much that it becomes unrealistic. What I like better is the "sweeter" sound.
QUESTION#3
The pre-regulators are 3-terminal 78/79xx types. What do you think about replacing these with discrete drop in replacement types like Paul Hynes or the like? Worth the trouble?
QUESTION#4
The main regulators (at least that's that I think these are) are National Semiconductor LM317LM SOIC-8. Any better drop-ins to be had?
http://octopart.com/lm317lm-national+semiconductor-9152
Well, that's all I can think of for now. I hope it's not too many questions.
Please give me any other ideas you might have but I want to address the components first before I get into the tweaky stuff. The purpose of this thread is only to improve this dac's performance tuned for my ears and nothing else. Not I need to move my speakers, isolation, bass traps, cables, etc etc. Thanks!
