Originally Posted by
colinB
Been buying on e bay again. Tonight ive cleaned a few Lps with my new Okki nokki and im using a record clamp, both arriving this morning.
The record weight is all the way from the Ukraine , an optional extra for the Musical Fidelity M1 , it looks like a Michel clamp but weighs 350gm and is made of Berylium copper.
Listening to Neil Young Zuma that sounded pretty rough , crackly and dull,sounding pretty sublime now. Thanks to Chris for kindly showing me what a clean lp sounds like. Dead chuffed
I bought a Spin Clean record cleaner, a basic affair where you manually rotate the record in a bath of cleaning solution with a pair of velvet covered pads which scrub the grooves. Rinse off and dry. It makes an amazing difference to the quietness and sound.
http://www.spincleanrecordwasher.com/
One day I will buy an automatic one like the Okki Nokki.
I also use Magic Eraser to regularly clean my stylus's, it makes a huge difference as well. You just have to be careful just to lower the stylus into it using the cueing device, as it is easy to damage the cantilever.
Phillip.
Records... the Vinyl Frontier. These are the voyages of the turntable Perspective. Its five-year mission: to explore strange new records, to seek out new artists and new sounds, to boldly go where no hyper elliptical diamond stylus has gone before!
Polk Audio SDA 1C + Yamaha C4 / M2 + Custom Made DIY Phono Stage + Pro-Ject Perspective + Pro-Ject Speed Box II + Benz Micro Ace = Magic.
