Originally Posted by
goraman
If the source sucks how can amplifying a bad signal even with the best amp make it better? No, it can't.The speakers can't make it better and even in a great room it will still sound like crap.The further you go down the path the bigger the problem becomes.
Start with a great source and then get a better amp later better speakers.
Most people build there audio systum backwards but I was shown early on the mistakes in that approch.
Ah yes, the "rubbish in, rubbish out" approach.
In my youth (he says stroking his white beard) conventional wisdom said the greatest problems were with the transducers - microphones and phono cartridges at one end and loudspeakers at the other. For playback systems that meant turntable/arm/cartridge and speakers. The amplifier was benign in comparison with the errors introduced by the mechanical transducers.
Enter digital sources and the problems of a front end mechanical transducer in the playback system disappeared. A digital source is now so good as is the following electronics that even ordinary production electronics will feed a decent signal to a loudspeaker. That is where the big gains are to be had by upgrading - put the cash in the only mechanical transducer in the home - the speaker.
Abandon all the compromises of a mechanical transducer at the front end and the signal is pure and undefiled all the way to the speaker which is where the problems are, and where the resources should be committed.
A decent digital source solves the "rubbish in" problem immediately.
Now I know many will disagree - but that's life.
Brian
In Southampton: Raspberry Pi 4 running PiCorePlayer, Beresford Caiman SEG, Quad 77 Int Amp and CD Player, AVI Neutron 4, Sennheiser HD25 headphones.
In Nicosia: Small Format HTPC, Beresford 7520 ,Quad 405-2, Quart 980s German Tower Loudspeakers.
