Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: A curious thing has happened?
    Maybe a wire is loose or crossed.
    Biwiring should be suddenly causing hum.
    Thorens TD550, Ortofon 12", Ortofon Jubilee or Koetsu Black; Rothwell MCL SUT, VTL 2.5 pre, XTC POW 1 power; Naim CD5x; KEF Reference 3.2's; Van den Hul interconnects and speaker cables.
    I'm Stephen.
    Quote Originally Posted by Puffin View Post
    You did remove the links between the HF and LF speaker connections?
    Can't really get to the back of the amp to take pictures. What are you looking for??
    I have removed the links and double checked all connections.
    I have routed the new cables in a similar path to the old ones (QED). Could try re-routing separately??
    I'm Rob.
    Stephen, the connecting links will be on the binding posts on the back of the speakers.
    https://youtu.be/ZCBe7-6rw4M
