I ordered the blue, 2.5mm.
Should be here tomorrow. Will report findings.
Does it need to burn in before giving it's best??
I'm Stephen.
I'm Stephen.
I have been advised that using 6mm cable instead of a thinner one, 2.5 or 4mm is not necessary, and you won’t hear a jot of difference.
This from a highly respected cable maker from these parts.
I used to be of the opinion that thicker was better (ooh er matron!) until I made the comparison physically.
No difference at all.
Bluesound Node 2i
Audio Analogue Pucinni SE
B&W DM607 s2
Klotz ic’s
well i can say that in the case of the 4mm to 6mm there is a difference,ymmv.im happy to stick with the 6mm
My System
John Wood KT88 Amp.
Paradise Phono Stage
Sony TTS-8000 Turntable.
PMAT-1010 MK6 Tonearm.
Ortofon Cadenza Bronze
Sony X555ES Cd Player
Yamaha NS1000m Speakers
2mm
My System
John Wood KT88 Amp.
i have 2.5mm van damme studio and 6mm . more than happy with the performance of the 2.5mm
Eric Bibb
