Micro-Seiki CDM-2 - partial dissection
I've been living with an occasional "cracking" sound from my CD player and I finally lost it when the drawer decided to go slow and squeal.
Removing the thing from the cupboard is a royal pita, as this machine is so darned HEAVY - far more than I remember the CD94 donor machine being.
First, a pic of the Sicomin platform-
For some reason, adding this thing made the same difference as adding the Trichord Clock 2 (more of this later) - I had two of these machines to compare..
Here's the machine "on the bench" - well, a rickety Dunhelm Mill TV table
First to remove the solid rosewood end cheeks-
Then the heavy milled top which was re-sprayed by Target Audio-
This is the inside - copper city..
The DAC board is mounted on the side and the Trichord clock is neatly fitted next to it. I removed the rear copper "lid" and this shows the added balanced output board Micro Seiki added, together with the HiFi grade Elna caps..
I think the basic supply board is Marantz, but there's much changed I think. I have a couple more shots of the mech and elaborate "drive-cord" drawer mech and I'll post them tomorrow. For now, the bigger drawer belt is too badly stretched and will have to be replaced.
Something else, there seems like a waxy substance around all the supply caps. I don't think it's leaking caps, as even a couple of small ones have this. I still think the two Elna "HiFi" grade ones may need replacement, but I'm too much of a coward to try to delve any deeper. perhaps the thick MDF/Rosewood bottom could be removed to gain access, I don't know at present. The engineer I'd trust with my life and who had another of these packed it in several years ago and is probably retired now
If it does go to anyone for service, it'll have to be taken as I wouldn't trust a carrier......
Just thought you chaps would like to see another good player from the "Golden Age.."
