Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Calling All Mullard Experts
    I'm InSpace.
    Hahahahahahaha......
    There's a bit of a clue in the sellers name.....
    Shian7
    Kudakutemo
    kudakutemo
    ari mizu-no tsuki
    Though it be be broken -
    the moon on the water.
    - Choshu.
    Quote Originally Posted by Mike View Post
    Nikola Tesla
    www.tubedistinctions.co.uk
    Matthew 5:10
    I didn't even get that far (no need to) - I just looked at the picture of the valve!
    I'm ChrisB.
    Quote Originally Posted by anthonyTD View Post
    if you want a real good all-rounder, then i would take the CV4004/M8137 [box plate] in most applications.
    their not cheap now but they have a long life [typicaly 10,000 hours] so probably the last ECC83 some of you will ever need!!!
    A...
    I'd agree with Anthony here - those were the best I found for my phono stage, Marco's Telefunken's being a bit too 'Knopfler' compared to the 'Hendrix' of the Mullards!
    I'm Nobody.
    Truly the king of ECC83/12AX7s - at a price!
    I've not had all that much experience with tube rolling but the Telefunken tube are fantastic, miles better than the overrated ones people recommend from time to time.
    I'm ThinkingOfHorns.
    Quote Originally Posted by Andre View Post
    I think it's horses for courses though Andre! I think it can depend on the amp or whatever it's used in.
    I shelled out a pile of £s for a NOS Telefunken ECC801s (12at7/ECC81 varient) after being told it's the dogs b*****ks for my headphone amp. I found it to be quite shrill & not a patch on my favourite 1959 Philips Miniwatt 12at7 or even my reserve Mullard M8162/CV4024. Perhaps in another application the Telefunken ECC801s may well live up to the hype.
    As I said earlier an Ecc83 Telefunken 'Smooth Plate' sounds great in my phono stage!
    alfie
    Main System: Denon DP-6000 VPI Base/Fidelity Research FR64s/Ortofon SPU Royal GM MKII/Shelter 901/Auditorium 23 SUT/Pure Sound P10/SB Touch or Audio Note CDT & M2Tech Young Dac/BL Audio LP-1/New Audio Frontiers KT66 Legend/Living Voice OBX.
    2nd System: PC/Foobar/E-MU 0404 pci (Modded)/AVI ADM9/Rel Strata II subs.
    Hi Phillip
    Your enquiry gives me the opportunity to remind members of the AoS Library. In this library there is much useful valve data :
    http://theartofsound.net/forum/showthread.php?t=3285.
    I cannot speak from experience, as I have only a few items that use valves (three tuners and one reel-reel tape deck), none of which are being used at the moment. All use Mullard brand valves and all the spare valves I have are Mullard NOS. I have not had an opportunity to do any 'tube rolling', though this is a planned activity I intend to try out on one of the tuners.
    Two sites which might interest you are:
    www.tube-classics.de/indexen.htm
    and
    www.tubeworld.com.
    See how you get on with these sites.
    I would add that valve connoisseurs talk about valves in much the same way a wine connoisseur will talk about wine - and all will have their favourites.
    Briefly, however, it seems that the Mullard brand ECC83 was made between 1959 -1969, and came in two versions: short plate 14mm and long plate 17mm. The long plate is thought to be better. All Philips brand (including Mullard) ECC83 are of good quality.
    Regards
    hi all,
    barry is right to a point, there are two main diffrences in the plate structure as far as size, they are 15mm and 17mm, but there are also a multitude of other unique diffrences in physical contruction to take into acount, some of which are; copper or steel grid pins, halo or D type getters, diffrent anode/plate coatings etc,etc... MULLARD, BRIMAR, PHILIPS valves were all part of the BVA [british valve association] so for eg; a valve branded as PHILIPS or BRIMAR could infact be a re-branded MULLARD. the type of structure will tell you a lot if you know what to look for! of course date codes go a long way in defining where and when a valve was made.
    hope this helps.
    A...
    Nikola Tesla
    Matthew 5:10
