Originally Posted by
lovejoy
The unspoken rules of iTunes:
1. Stick with the version that works for you and don't let Apple bully you into the newest version.
Awesome advice. Here are some other suggestions (keep in mind I have iTunes 7 and I am assuming iTunes on a Mac so the menu items may be a bit different for different version/OSes)
lovejoy
3. Always keep back ups of your library files, including playlists so that if you do suddenly find your iPod empty, you can at least re-fill it quickly enough.
The command "Export Library" actually exports all of your playlists to a file named library.xml. The command should really be labelled "Export ALL playlists." You can use a program like carbon copy cloner to backup all of your music and and all of your playlists (in library.xml)
lovejoy
5. Switch off the equaliser, volume normaliser, sound check enhancer etc.
Also, set your volume in iTunes to maximum or 100%.
By doing those steps above AND to set your Audio Midi control panel appropriately, you will have iTunes configured for either bit perfect output or the best sample rate conversion performed by iTunes and not OSX.
Note that iTunes sets its sample rate according to what is specified in Audio Midi when iTunes launches
For example;
your iTunes library has mixed media files, some 16/44 and some 24/96 audio files. In this situation set your Audio Midi to 24/96 to feed your 7520/Caiman. When iTunes launches it will configure itself for 24/96. Any 16/44 files will be upsampled by iTunes to 24/96 and passed to OSX will then pass them on to the Caiman. This won't be bit perfect for 16/44 files, but it will use the best sample rate converter within iTunes and not OSX. Of course, 24/96 files will be bit perfect.
Example 2;
your iTunes library has only 16/44 files. In this situation set your Audio Midi to 16/44 to feed your 7520/Caiman. When iTunes launches it will configure itself for 16/44. Any 16/44 files will be passed by iTunes to OSX and finally passed on to the Caiman. Thus you will have bit perfect output for all your 16/44 files.
Hope this helps!
David
iTunes 7,PowerMac G4 733, Mac OS X 10.4.11, Airport Express, Beresford TC-7520 (Dual LM4562NAs) MLC5/6 clipped, 36K and 100nf cap mod, Behringer EP2000, Cambridge Soundworks Tower II
