Hi Mike
I don't know TBH. The arm mount has both 9" and 12" arm holes with a piece of rosewood that you can reverse to suit...Its a simple but clever way to do it...
The 12" Schroder is 295mm and there is a suitable hole (approx 20mm) to allow this, Ive not tried any other arms on the actual unit.
The slate is thick but (as I understand) softer than some of the UK type so I would guess could be drilled to suit...
It is a really nice unit, Ive been to Inspire and I wouldn't swap mine with any of the Enigma ones they do...
I may be persuadable to part with etc Schroder ... but it would be at a price....
StSt Motus DQ + SME 312 'MB Special'
Transfix Axia / HM7
Art Audio Vinyl 1 Ref
Modified Mac Mini/Weiss DAC 202
SJS Model 2
BP P20 (SJS upgraded)
Trenner and Friedl RA
[/SIZE]
