I'm Nobody.
Well not really anyway.
Apart from cables, that is.....
I'll just get my coat.
Shian7
Kudakutemo
kudakutemo
ari mizu-no tsuki
Though it be be broken -
the moon on the water.
- Choshu.
What is for sure, there's loads of humor in AoS.
Dimitri.
George Orwell
We've been here before, lol!Apart from cables, that is.....
Out of interest, Mike, do you consider tube-rolling or component upgrading in equipment, also as a form of tonal manipulation?
Shian7
Kudakutemo
kudakutemo
ari mizu-no tsuki
- Choshu.
I agree; that's why I think it's always important to consider the bigger picture with these things...
Nightmares with work for the last week so hardly been at home let alone AoS - however I am really not surprised this thread ended up the way it did... I had a bad feeling from "Matts" #1 introductory post, and sadly turned out to be right. Hey ho, that's life, I'll get me slippers.
Alex
Amplifier: Rega Brio R. Speakers: Spendor SP1. Cables: Various, mainly Mark Grant. Please see "about me" for the rest of my cr@p! Gallery
I applaud your instincts, Alex
It shows how dedicated you are that as soon as you're home, and near a comp, you come and say hello
Room correction is all the rage these days and with good reason. Unlike the other posters so far (I think)I use an Onkyo 875 av amp which has Audessey room eq built in. My findings show its room and kit dependent. My old speaker setup was a pair of Ruark Talisman II fronts with Ruark centre which never got on with my new house when I moved something was missing. Running Audessey helped match the tonality and improve the sound field. At least that was when the calibration was done properly as its far from simple getting an accurate picture of a room.
I then changed to those white things in my Avatar and found that bypass mode worked better when listening to stereo especially. I then re ran the room correction and once I followed direction to the letter from Neil I found little difference between the two with Audessey edging it. I concluded that my old Ruark setup was far more room sensitive.
Paul
Onkyo 875, Monitor Audio RX6 GW,Monitor audio RX centre GW,Monitor Audio BFX rears, REL QUAKE,Arcam CD73t CD ,Russ Andrews Yello mains cabling & PBJ interconnects,Sterling Black Mamba speaker cable.
