Results 21 to 30 of 35
Thread: Went Round To Oliver's (Bigman)...
  1. #21
    Bigman80 Guest
    Quote Originally Posted by STD305M View Post
    Take them with you Grant, they're almost big enough to be buried in
    you can come down with them Grant, we can get you stuffed and placed by the fire
  2. #22
    if we chop up his corpse in the bathtub *mafia-style* we could get all of it in just one of them.
  3. #23
    na, your getting a loan of Macca's
    Yes plan is when my Tannoys arrive Oli's going to have a loan of the JM Labs and see how they play in his room. They are front ported so should not excite the glass doors and their output drops like a stone below 40Hz so they are unlikely to boom. In fact Chris who I bought them off was using them in a similar size room to Oli's and they sounded just fine. If it doesn't work out then he's still got his Pioneers to fall back on and my living room fills up further with more large, unused speakers...
  4. #24
    you'll have to fight my mate for them..lol alas no bathtub tho, but like the idea of getting stuffed and sat on the couch.... could maybe get firebottle to rig up a motorised jaw and a tape player all remote controlled.. i could then talk
    Bigman80 Guest
  6. #26
    Bigman80 Guest
    I'll have a word
  7. #27
    Bigman80 Guest
    Yes, and I'm very grateful mate. Will be good to be able to freely listen without the necessity of having to like them. Which you do when they are your only speakers.
    Will just add again, I really like the pioneers!!!
  8. #28
    All assuming I like the Ardens better than the JM Labs and that isn't a given because the JM Labs are a significant cut above your typical multi-driver floorstander. If I hadn't decided to scratch the Tannoy itch I'd be sticking with them. Their equivalent in the current Focal range cost over five grand!
  9. #29
    I'm Edward.
    So your getting cabs for your Tannoys sorted out at last Martin? Who by? The guy Marco used for his motor?
    Oops, this is a thread about Oli's stuff. apologies.
  10. #30
    Bigman80 Guest
    Quote Originally Posted by Edwardlon View Post
    It's all good, carry on!
