Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
Thread: Newbie after advice on budget TT
    I'm Gary.
    Default Newbie after advice on budget TT
    Hi Guys
    I joined yesterday & am thinking of getting back into vinyl.
    My last TT was a Garrard Sp25 and that was probably 20 years ago, I'm using a Pioneer A656 Reference amp, which has MM & MC phono inputs and Quadral Rondo Phonologue speakers.
    My record collection is mostly from the 70s/80s and after being stored in the loft for 20 years may not be in great condition. As the records may possibly be unplayable I'm not looking to spend a lot on a turntable, somewhere around £100 - 150. As my wife is more concerned with aesthetics than sound it must also look "nice"
    I've been thinking along the lines of Pioneer PL12D or Dual CS505?
    Anything else I should consider?
    Thanks
    I'm Gary.
    Get a Knosti manual record cleaning machine first about £50 new and clean your records first.
    My records had been in the loft a similar amount of time, cleaned up beautifully and played well. Some even had mould on them.
    Gary
    Quote Originally Posted by Gaz View Post
    Hi Guys
    Thanks
    I'm Gary.
    Think about a modern Project turntable, for your budget maybe a better bet, will get you on the vinyl ladder and see where you go from there.
    Good hunting.
    Gary
    I'm Adrian.
    Good hunting.
    Gary
    I would agree aim for at least £150-200.
    If you are able to go higher and can find one then a Pro-Ject Xperience 2 Pack 2nd hand in good condition is a very good option. The generally came with an Ortofon Red cartridge occasionally a Blue if the customer upgraded. I sold mine a couple of years ago for £500 when I upgrade, I found it an excellent TT, very detailed and good sound, very good value for money. The new incarnation of it is about £999.
    It a ptoject 2experience sb dc and is now£1,100
    Comes fitted with ortofon 2m silver
    If your budget can streatch the project elemental is available for around £175 if you shop around
    Steve
    Turntable; Rega p8
    Cartridge; Alpheta mc
    Amplifier; Rega Elicit
    Speakers; Rega Rx3
    I'm Gary.
    Thanks for the advice guys
    Had a quick browse on Ebay, are Project Debut and Elemental any good? There seem to be lots of them for sale, is that because they're not great?
    I'm Adrian.
    Quote Originally Posted by STD305M View Post
    Steve
    Check this out https://www.richersounds.com/hi-fi/t...-dc-acryl.html
    Still 5 times the guy's budget
    Not sure I'd want a plastic turntable
    The wood version is £1,100
    Turntable; Rega p8
    Speakers; Rega Rx3
    I'm Gary.
    Default This?
    https://www.ebay.co.uk/itm/Pro-Ject-...t1Kq:rk:9:pf:0
    States the "cartridge needle" is broken, I would imagine worst case scenario this may mean a new cartridge?
    If so what would be a good replacement & is it an easy procedure to change it?
    Nice turntable for the money
    Not expensive to replace the cartridge
    Turntable; Rega p8
    Speakers; Rega Rx3
