Results 1 to 10 of 14
Thread: Not a good start to the day
    I'm Andy.
    Default Not a good start to the day
    Had my garage broken into last night :angry: Took only one bike so I think they will be back soon for more!
    To cheer myself up, thought I would listen to a few albums and fired up the kit to be greeted by a very horrible sound coming from the speakers.
    Was using the Orbe which has an MC cartridge, so quickly changed to the Lenco (MM cart) and everything was good so not the amp and the phono stage supports both turntables.
    Flipped the phono stage over as you can change the settings for the resistance - had it set at 110 Ohms which it had been on for many months with no issues - changed it to 440 Ohms and the sound is now correct.
    Any idea why?
    Cheers
    Main system:
    Analogue.
    Network Player.
    Digital.
    Philips DCC 730 player
    Marantz CD50SE
    Amp.
    Audiolab 8000A
    Speakers.
    Reiver Jenna floor standers
    HeadPhones.
    I'm Robert.
    Sorry to hear about the break in Andy.
    Probably a good idea to secure things up a bit, as you say they may well come back when they think the heat has died.
    Night sensor light, a few tuf locks around the garage or even one of those ground poles assuming the door opens outwards ?
    A camera is easy to do and not expensive.
    All the best and good luck with the system mystery.
    My System:
    CDP - Pioneer PD-91
    motion sensor wifi camera ....
    this looks a good deal https://www.amazon.co.uk/dp/B07CVDZ8...9-530a15f05916
    Geoff
    I'm malcolm.
    One of these:
    Audiophile Tosher
    I'm Andy.
    Thanks all (especially Malcolm......)
    Will put in better security - plus a big sticker on the garage door saying it's alarmed.
    Main system:
    Analogue.
    Network Player.
    Digital.
    Marantz CD50SE
    Amp.
    Audiolab 8000A
    Speakers.
    HeadPhones.
    I'm Gary.
    Most people on hearing alarms ignore them, they don't ignore a shotgun being fired.
    Alarm mines are really useful, they use a blank shotgun cartridge.
    I have set one of the ones I have off inadvertently and I nearly p**ssed myself.
    To be absolutely sure of complying with the law I have a sign on my workshop:-
    ALARMS SET
    BEWARE DANGER OF DEAF ( looks like death from a distance)
    BLAST RADIUS 2 METRES
    DANGER OF BURNS.
    My trip wires are fine strong fishing line. Arranged at different heights. Doors and floor. Rear Gate etc.
    Gary
    Quote Originally Posted by gninnam View Post
    Any idea why?
    Cheers
    can only think someone has changed the settings inadvertently at some time or there is a fault in the mc side of phonostage somewhere
    I'm Andy.
    3 adults in the house and I am the only one who uses the hifi so not touched by anyone else.
    I suspect its the phono stage also - I have an old Michell ISO that I will try and see what happens.
    Main system:
    Analogue.
    Network Player.
    Digital.
    Marantz CD50SE
    Amp.
    Audiolab 8000A
    Speakers.
    HeadPhones.
    440 ohms should suit the Benz better than 110 (strange impedances), though this does depend on other factors, incl. the ph/stage. Whereas my Ebony preferred 220 (and hated 100) on my Superline, I've read of many Benzes sounding better at around the 400 mark.. So maybe the former loading was the wrong one (more bass but flatter and less involving).
    I'm Andy.
    Dirty switch contacts or switch contacts not touching properly. If a contact is very marginal even a change in the temperature or humidity is enough to make it fail. Just wiggling the switch can cure it.
    Sorry to hear about the break-in.
    Cheers - I don't think I moved it back to 110 so might try it tonight - thanks!
    Quote Originally Posted by Mike Reed View Post
    It's a Goldring Elite and was sounding fine at 110 until yesterday when it just sounded distorted.
    I admit that at 440 it is sounding good...
    Main system:
    Analogue.
    Network Player.
    Digital.
    Marantz CD50SE
    Amp.
    Audiolab 8000A
    Speakers.
    HeadPhones.
