Results 1 to 10 of 14
Thread: Anybody have some grip rubber ?
    I'm Robert.
    Default Anybody have some grip rubber ?
    Does anyone have some rubber suitable for the vta adjust arm as seen here https://goo.gl/images/Z1oiMK
    Mine is a bit perished so i need some suitable rubber to cut and stick in place for finger grip when adjusting.
    Cheers
    Rob
    My System:
    CDP - Pioneer PD-91
    I'm Gary.
    Cheers
    Rob
    Bicycle inner tube repair patches, the repair kit comes with different sizes, I sure you could cut one to suit.
    Gary
    try some cable shrink wrap maybe?
    Is the 'grip' provided by a textured rubber cover, or is the metal part knurled? It's not clear from the photo
    Hi Robert
    Try a fishing tackle shop, it looks very much like the kind of rubber or silicon tubing they use for rigging up pop up boilies
    Regards Steve...
    Turntable; Rega p8
    Cartridge; Alpheta mc
    Amplifier; Rega Elicit
    Speakers; Rega Rx3
    I'm Robert.
    The rubber you see wraps / sits on the metal, in a smooth space channel about 1mm deep.
    The rubber also has grooves horizontal to the vta adjuster. You can just about make them out if you have a screen that enlarges like a phone screen.
    My System:
    CDP - Pioneer PD-91
    That's what I thought. Do you know the diameter of the channel? Some three-core mains cable have a textured rubber outer cladding. Perhaps a portion of this could be used.
    I'm Robert.
    Hi Barry,
    Dont no the diameter as i'm on hols.
    I'll measure when im back start of September.
    My System:
    CDP - Pioneer PD-91
    I'm Richie.
    I’ll measure mine tonight, if it helps?
    Quote Originally Posted by martian sunrise View Post
    That's what they all say
