Results 11 to 20 of 21
Thread: TV/SKY/DVD Connection help required
    I'm Lee.
    Oh, nice one Hamish.
    I'm in a pickle at the moment. Our Sky+ box is nearly full and I want to archive some stuff off it, but I'm beginning to think that the DVD REC is too much hassle. I might ditch the it in favour of a DVD/HDD recorder. Or, perhaps I could upgrade to Sky+HD which has more capacity. At the end of the day, recording from the Sky box is a real time affair isn't it?
    Any recommendations in the DVD/HDD box market? I'm way out of touch in this area.
    Lee
    Independent Apple tech support guy at Macnology
    Gear: iMac > ALAC > Airport Express > Beresford Caiman DAC > Mark Grant IC > Audiolab 8000S > Chord Rumour Speaker Cable > Dynaudio Audience 42 Speakers > Grado SR80 Headphones
    Vinyl: 90's Rega Planar 2, RB250, Bias Cart, Rega Fono Mini
    Last.fm
    I'm Lee.
    Quote Originally Posted by hamish View Post
    Does the fuzz look like interferance? Does it sorta move over the screen in lines?
    No it doesn't. It just apparent around the edges of things. The Sky menu shows it up quite badly, but it's noticeable on the general viewing picture too.
    Lee
    Last.fm
    pm m eyour addy and il chuck an ixos scart i have found in the post to you on monday ... we might have another s/h one at the shop i could let you have cheap too.. that will at least help answer this queery!
    any hdd/dvd-r is going to mean real time recording unfortunately , but a hdd one would at least provide you with less limits on the time you can record for .. if that makes sence?
    dvd/hdd recorders... we sell the sony dc205 http://www.sony.co.uk/product/dvd-recorder/rdr-dc205 they have gotten pretty good these days and the picture quality is very good with the hdmi conectivity (obviously you need a hd tv for that?) ... but you have to ask your self how important it is to you that you keep the stuff you record... as at over £200 its a lot of money for occational use!
    the new sky hd boxes are great, but once again only if you have a hd tv... other wise its just a bigger hdd!
    Quote Originally Posted by webby View Post
    ... gawd knows... scart issues usually show them selves in lines that move over the screen ... but i guess thats not always the case... do you have any other options for output on the dvd/r .... i could just be as chris said, the decoder out put is crappy.
    have you gone into picture setting on the sky box ... i cant remember if ou can control how both outputs output... might be worth a look though
    I'm Lee.
    Yep, I have an HD TV, the Panny 42px80
    Lee
    Last.fm
    I'm Lee.
    I'll have a look at that.
    Lee
    Last.fm
    ... same as me (well mines a 37... i think we have spoken about this before actually breifly...)
    get your slef a free upgrade to sky hd box then... make you of those hdmi sockets if i were you!!
    I'm Lee.
    Yeah, but it's that extra £10 a month that irks me. We'll see.
    Lee
    Last.fm
    Nah, just blag them that your gonna ditch sky for freesat HD unless they give you it for the same price your currently paying.... Bet you they do!!
    It seems to me that you are not getting RGB out of the sky box passing through to your TV. Ensure the Sky box is set to output RGB in the setup menu for scart and connect the scart to TV out no VCR as that does not pass RGB (had a similar setup and was miffed at the recording quality as well till I did this). Then ensure that your Dvd recorder is set to output RGB via the scart and then ensure that you have the scart cable connected to the correct scart socket on your Tv as not all scart inputs accept RGB. Failure to ensure RGB passthru will result in a composite signal full of noise. Obviously you will only be able to watch live Sky via the DVD recorderswitched on but for archive purposes I'm sure it is worth the hassle.
    No regards scart cables. Some very old ones wont allow RGB but there is no need to spend much just ensure the cable states RGB compatible on the box higher quality ones do have some effect but a decent low cost Techlink works as well as anything.
    I had a setup like this a several years ago so not sure if it still applies but SKY2 would not record due to copy protection and I couldnt be bothered buying a macrovison stripper. Not sure if Sky still do this with some channels or programs which I gather was down to the Production companies of some of the programs.
    Paul
    Onkyo 875, Monitor Audio RX6 GW,Monitor audio RX centre GW,Monitor Audio BFX rears, REL QUAKE,Arcam CD73t CD ,Russ Andrews Yello mains cabling & PBJ interconnects,Sterling Black Mamba speaker cable.
