Page 1 of 28 12311 ... LastLast
Results 1 to 10 of 271
Thread: Solid state preamp grain compared to valves
    Default Solid state preamp grain compared to valves
    I've tried a few SS active pres and I haven't been able to get on with them, ultimately I find the sound irritating. I've put this down to a slight silicon grain even on good ones (eg. Audio Research). I've also matched them with a few modern SS power amps that seem to smooth out the grain but they make the sound dull and lifeless. I've never had this with valve pre amps (sometimes harshness with cheaper ones or cheap valves, but never the "grain"). Nor with good passives.
    Is it in my head, are my ears/brain sensitive, or is this just the way it is?
    I'm inthescottishmafia.
    You like what you like, end of really. What I’ve found is that any active pre isn’t really transparent, they all add a little something to the sound. The Slagle AVC I had was better to my ears than any active pre I’ve tried in my system previously, however I’ve sold that as I got hold of a set of Tribute AVC’s which Anthony of BTE Desgns is putting in a nice box for me. I’m hoping these will be even better.
    Hunter S Thompson
    Bigman80 Guest
    The Slagle has an undeniable fluidity. It's a fantastic pre.
    I have the DCB1 preamp now and have a better bass control at the expense at a very very slight loss of that beautiful fluidity. It's as good at the soundstaging and to be honest, it's got a slightly better resolution but it really is nip and tuck.
    As for grain, Not to my ears and I've just swapped to a Monarchy Audio SM-70 and DCB1. Both solid state. It definitely has more bite and grit but I really like that. Like Ali said, it's whatever you like.
    Wide bandwidth, and the ability to be able to drive [properly] the cables, and the front end of what ever power amp your using' these are two very important aspects of a good preamp!
    A...
    Nikola Tesla
    www.tubedistinctions.co.uk
    Matthew 5:10
    I fully agree, which is where some passives can fall down.
    I know where you're coming from Lawrence, as I've experienced the same. However, not all SS preamps are like that; it simply depends on how they've been designed, and crucially, how they 'gel' with the partnering power amp.
    Therefore, the effect you're hearing is often more likely to come from a pre/power amp mismatch (and sometimes the cables used), than any defined sonic signature of silicon.
    That's why, in my experience, pre and power amps (valve or SS) should always be viewed as a pairing, and therefore considering their respective electrical requirements (and sonic signatures, so that synergy is achieved), is vitally important to get a good sound.
    Too many folks, when buying hi-fi equipment, don't build SYSTEMS; they simply assemble a disparate collection of boxes, and somehow expect them to make music. Unfortunately, that's not how it works!
    Most pre-amps are rubbish whether they are valve or solid state.
    Best valve pre-amp I have heard is Marco's heavily modded Croft. In fact that is pretty much a custom build really.
    Best solid state is Barry's Mark Levinson. I'd have one if I could find one and afford it.
    If you can't afford to spend thousands on an active pre-amp get a quality passive and use a compatible power amp.
    Yes, that's pretty sound advice. A lot of potentially good systems are hampered by a poorly matched and/or designed preamp.
    However (and I know this is not what you're saying, but it's often stated as the case), it's also a fallacy that simply sticking a passive preamp into a system will cure 'all the ills' of an active design.
    That simply isn't the case, as is the notion that passives are automatically more 'accurate'. They're not accurate if they're mangling the music signal, because they're being used in the wrong system or with the wrong power amp. You have to get it right.
    And yes, the VERY best active designs, valve or SS, don't come cheap. The same applies to phonostages.
    I'm Neil.
    Some of that “grain” could be in the recording itself, where some of the more euphonic valve pres would gloss over it.
    Know what you mean about solid state grain though, it’s rare to find solid state gear without it when comparing to valves, just as it’s rare to find solid state precision and tautness with valves.
    Agree but we shouldn't confuse 'grain' in the recording with distortion added by the system. A lot of what people think is 'On the recording' really isn't.
