Results 1 to 4 of 4
Thread: IFI Micro iTube 2 buffer and preamp
    I'm charles.
    Default IFI Micro iTube 2 buffer and preamp
    Just wondering if any members have any experience of the above mentioned device particularly in buffer mode.
    Thanks.
    I'm Marcus.
    It just so happens that I do. I would say that at this point, with my current equipment (no other tubes in the system), it is something I can't live without. It adds solidity, dimension, even more oddly, clarity, particularly to the mid-range. Without this gizmo, the music sounds more, hmm, 'grey', flat.
    The three different tube types do actually make quite a difference - I'm fond of the push-pull, it softens the treble a bit more than classic tube.
    The downside is needing more cables, and they should all be of at least the minimum quality you would desire from a single cable.
    I actually don't find any noticeable differences using in pre-amp mode, into the preamp inputs - that way, you can still use balance controls, remote volume control etc. I just twist the volume control to full on the iTube.
    The 3-D sound and bass boost options can also be very effective, but obviously depends on the rest of your kit and room setup.
    Certainly worth a try.
    Ziro power cables -> Modded Marantz CD63SE or Bluesound -> Roksan K3 Dac -> RFC Venus -> Onix DNA 45 -> LS25 -> Proac D18
    I used a v1, unfortunately the cheap pot has a big imbalance at low levels and I couldn't use it at night. Marginally liked the overall effect though.
    I'm charles.
    Thanks for your replies. Have just ordered version 2 and a review will appear after it arrives and when I've had a careful listen.
