Results 1 to 10 of 17
Thread: Binding posts
    I'm sorted.
    Default Binding posts
    My Tannoys need new binding posts (one of the terminals broke off, looked like the metal had oxidised, weird?) so I'm after recommendations for suitable replacements.
    I've seen these -
    https://www.ebay.co.uk/itm/4-Heavy-D...oAAOxygj5SgCZq
    But am open to any suggestions. (they need to be long to go through the 17mm backboard).
    Thanks very much in advance.
    Hi charming Roy,
    I've used these before and they are excellent. I've never found them this cheap before, I've just ordered two sets.
    https://www.ebay.co.uk/itm/4x-Speake...item2f1a94d980
    I'm Allen.
    Roy , you can get binding posts or you can get binding posts . Aparently size matters
    IMG_0415 by Allen Wells, on Flickr
    Simple rule of thumb with binding posts: If you wouldn't feel comfortable using them to moor a battleship, in a hurricane, then they aren't big enough.
    I'm Allen.
    I could moor a aircraft carrier with the BIG ones
    I'm Ian.
    If it's long you want these are good. I used them through 18mm birch ply.
    https://www.kjfaudio.com/product/jan...binding-posts/
    I'm sorted.
    Hi charming Roy,
    I was wondering if anyone had noticed that, I've been various 'flavours' before
    Thanks everyone for your input but Al, don't think posys will cut it
    I'm Russell.
    I broke the terminals off an old amp of mine, from years of over tightening. So, I soldered the speaker wires directly to the amp! Worked like a charm for 10 years or more.
    Russell
    I'm Allen.
    Now corrected
    I'm Adam.
    Never forget - If your binding posts don’t need to be tightened using an adjustable wrench, then they’re not chunky enough.
