Results 1 to 7 of 7
Thread: Valve phono stage with Naim pre/power amp.
    I'm Nat.
    Default Valve phono stage with Naim pre/power amp.
    Has anyone successfully tried the above I have an Olive 102/180 which replaced a 282/300 that I like a lot and so want to concentrate on my source I'm currently trying an old Red Button with an FR12 which I also really like and could replace my Cirkus/Lingo 1/Ittock LP12.
    I currently use a Trichord Dino/NCPSU stage and am curious to try a valve based phono stage so would it work with Naim and how nuch would I need to spend to better the Dino?
    I'm John.
    You would have loved the Phono Stage bake off last Sunday.
    I too use a Trichord Dino (mk ii) and we tested it against other solid state stages and valve stages.
    My conclusion: I'm definitely getting rid of the Dino and replacing it with a valve stage.
    If you want to spend similar money to the cost of the Dino then can I suggest you look at this stage that JohnG of this forum brought along?
    http://www.nixiekits.eu/product.php?key=digna_pp
    It comes as a kit from Germany but you could ask them to assemble it for you. It blew my socks off and is a great deal for the cost.
    Can't help with the Naim question as I use a valve integrated but I'm sure others will be able to.
    I'm Slav.
    Personally I don’t see any advantage of using valve based CD players nor phono stages , good SS stage is definitely as good as valves one if not better . Save some more dish and hold your breath till Paradise phono appear in Classifieds, obviously IMO
    I'm Deleted.
    There is no isssue with using a valve stage with the Naim, I’ve used loads of SS and valve phono stages with my Naim gear.
    Account Deleted
    Thumbs up
    Quote Originally Posted by Natara View Post
    I use a valve phono stage with my Avondale pre and power's and it works really well. Seek out a Vincent PHO 700. Very nice indeedly doodly.
    I'm Nat.
    Thanks for the replies.
    I’m not stuck on Naim they just happen to be the amps I like most from the ones I have tried.
    I’ve just swapped a 282/300 for an Olive 102/180 which are only a couple of years apart in production terms but to my ears sound quite different and I prefer the older Olive sound.
    I recently heard some big Tannoys driven by an old Leak 20 and if I had another house that would be my ideal system.
    But to get the bass I like from a smaller set up Naim does the trick and I thought a nice Valve phono amp might offer a bit more warmth.
    I'm Matt.
    I used an EAR834p valve PS with my Naim system many years ago. No issues with it whatsoever. It was a big upgrade from my Prefix I was previously using.
    In fact the 834 was my introduction to the world of valve gear & I haven't looked back since!
