Results 21 to 30 of 48
Thread: Aiwa Turntable Restoration
  1. #21
    Looks like you are going to have to work through this thing methodically from the cartridge pin inputs all the way through to the RCA outputs. You could be dealing with multiple faults here.
    If your anything like me you hate working methodically but sometimes there's no option.
    Anyway good luck with it. Anything can be fixed with enough effort.
  2. #22
    I'm Anto.
    Yes . I have an vintage Aiwa headshell coming in a day or 2 . Will be interesting to see if that makes a difference , although those universal fittings should all be the same ?? Or not maybe !
    When the strobe bulb comes ,I shall strip the armbase back again and check the resistance in the tonearm wiring ,with the headshell attached (I tested the spring loaded pins through to the solder point on the arm bottom . Not sure what can be done if those spring loaded pins are faulty!
    Cheers Martin
  3. #23
    Well if you already tested them they should be okay. I guess you have tried looking for a service manual? I must have missed that if you already said.
  4. #24
    Have you checked to see if the arm wiring is shorting in the armtube etc, as if the insulation has broken down it could still be making full connection down to base but could be shorting to either part of the arm or against another wire.
    I'm Anto.
    Good thinking Grant .
    The arm has a scale ring on it . I take it its to adjust VTF . I have read somewhere that you set the scale at zero, then get the weight at the back adjusted so that its see sawing , or around zero VTF, then adjust the ring to add the relavent gramm weight ie 2 will mean 2 grammes .
    Trouble is ,the ring doesn't make any difference at all , my little weight unit shows no difference ,wherever you adjust the ring to . In fact to get a vtf of about 1.6 grammes , I have to set the weight nearly all the way in !!
    So difficult to get anything higher (should you possibly need to )
    I think the ring has broken inside maybe ?
    Its a bit of an obscure Japanease arm apparently
  6. #26
    I'm Anto.
    Yeh , downloaded the service manual ,but cant find an instruction manual
    Here she is after a bit of polish
  7. #27
    And the service manual is no help.
    Re the VTF thing it could be that is by design? Isn't that TT from an era when a lot of cheap cartridges wanted very low tracking weight, like 1.2g? Seems to me it is just weight on a pivot, it can't not work, can it?
    Also on the Technics sL1200/1210 stock arm a lot of carts need the additional weight that screws into the rear of the arm.
  8. #28
    I'm Anto.
    Weight to the back of the arm means less force on the stylus? I am having to take the weight all the way in , so looking for more force . I will study the service manual again tonight , perhaps a few beers didnt improve my reading skills and concentration
  9. #29
    I'm Anto.
    By the way - I really really like the front cueing lever !! I thought - Whats this c**p , but it is so precise and also idiot proof ,in that instead of hovering your hand near a little cueing lever close to the arm , (where pissed people can make mistakes ) , the front lever is well out of the danger zone
  10. #30
    I'm Anto.
    Well , I have the afternon to myself in the mancave ,and after a few more applications of Servisol Switch cleaner to the inside of the headshell , and moving them in and out a few times ,we now have normal service resumed !
    The Aiwa headshell sounds a bit less refined that the other 3 but thats probably down to the limitations of the cart ?
    Feeling chuffed .
    Had some Marillion on,and Status Quo , and Mike and the Mechanics - Nobodys Perfect seemed quite apt really !!
    Hopefully if the strobe light replacement goes well ,I can have a keeper
