Results 1 to 6 of 6
Thread: David Millard new member
    Default David Millard new member
    Hi everyone I am a new member to this forum.
    My current system is:
    Two Pink Triangles.. an original DC motor and a Pink Triangle Export also have a Systemdek and other turntables
    Cambridge Audio and Audiolab amps
    Acoustic Energy AE509 speakers and lots of other speakers I like toying around with.
    I have recently brought two lenco GL75 and 1 GL69 turntables to upgrade the plinths and see what I can get out of them sound wise, thought they sound amazingly good anyway, any help or suggestions would be greatly appreciated thanks.
    Hi David, welcome to AoS
    Quite a few people here using the Lencos, both stock and tricked-up so you should find some helpful advice, start a thread in the DIY section.
    Ok thanks Macca
    Hello David. Welcome to AOS.
    Lenco turntables are very good. These days, I tend to think the L75 is nicest left largely in standard condition. They sound excellent anyway.
    The arm usually benefits from new V blocks and fitting a robust plinth works well.
    Enjoy the forum,
    Geoff.
    Thanks Geoff, the first 75 I brought is a Leak badged one in great condition, they are beautiful looking decks and this one is so good I don't want to change anything on it, so I have brought another one so I could make my own plinth and an arm change, I have put new v-blocks in the Leak because the original ones were not good.
    Have a read of my saga.... http://theartofsound.net/forum/showt...O-GL75-Project you might get some laughs and ideas
    PRE
