Page 4 of 4 FirstFirst ... 234
Results 31 to 33 of 33
Thread: Pre-amp recommendation please
  1. #31
    I'm kickinbacklistenintotchoons.
    If you're using only half the volume control's travel, reducing the overall gain would allow you to use more of its travel and the step sizes would be effectively smaller. It's worth considering. What's the maximum setting you ever use?
    Ah, now I see. That makes perfect sense.
    The max volume I use is about 60 - 65%
    My stuff -
    Analogue: Technics SL-7 / EPC-P202C, Remton 383 MkII phono
    For when there's no Analogue: Doge 6 CDP
    To discover loads of new music: Spotify via Laptop into Xiang Sheng DAC-01A
    Make music louder: Quad 34 pre, Nirvana Electronic Works A60, 60W / Ch Class A power
    Music boxes: Heco Celan 300
    Cleaning duties: Okki Nokki 2
    Y'know, sometimes, Satan, come as a man of peace.
  2. #32
    I think the Quad has 21 volume steps, but if you're using only about 60% of its travel you will be effectively using about 13 steps. If you attenuate somewhere along the line (or reduce the gain, which amounts to the same thing for this purpose) so you use 100% of the volume control's travel, you will have all 21 steps available to you and get effectively smaller step sizes.
    I estimate that about 10dB less gain, or 10dB of attenuation, should put you in the right ballpark.
  3. #33
    Yep, 21 steps and, usually, 13 max.
    My stuff -
