Results 11 to 20 of 33
Thread: Pre-amp recommendation please
    I'm kickinbacklistenintotchoons.
    Shouldn't be a problem to change the pot I think, from memory the original is quite large as stated above. Fitting the same resistance won't affect the sound.
    I have a feeling that the original isn't a stepped attenuator at all, just that there is an indent mechanism built into the pot. I wonder if that can be defeated to give continuous rotation.
    I will gladly look at it for you if you wish.
    If you think the stepped attenuator could be replaced / defeated, I would be happy for you to take a look Alan Thanks.
    My stuff -
    Analogue: Technics SL-7 / EPC-P202C, Remton 383 MkII phono
    For when there's no Analogue: Doge 6 CDP
    To discover loads of new music: Spotify via Laptop into Xiang Sheng DAC-01A
    Make music louder: Quad 34 pre, Nirvana Electronic Works A60, 60W / Ch Class A power
    Music boxes: Heco Celan 300
    Cleaning duties: Okki Nokki 2
    Y'know, sometimes, Satan, come as a man of peace.
    I have checked the circuit diagram and the volume control is an active stage, so I'm convinced the 'step' positions are built into the vol pot mechanism.
    However you can't just replace the pot with a standard one as the 'law' of the pot, that is the degree of change of resistance per rotational turn isn't standard.
    The pot is specially made for Quad with a special law to suit the active volume stage.
    If anything can be done it would have to be a mechanical modification to the fitted volume control.
    Do you reckon it is doable mechanically ? ie removing the indented ring (I assume) that retains the ball bearings (?) to imitate steps.
    My stuff -
    I would think so, they have to be assembled originally so dis-assembly should be possible.
    I was never a fan of the 34 myself, preferring the 44 in all its versions as I thought the sound clearer...
    The 66 and 77 were rather better again I thought, offering clearer reproduction of recording venue and greater dynamic contrasts on rock and jazz material. The 77 had a flaky remote system and this all but killed the original company I gather, but of you can find a clean one, you may love it as I do. The 99 was similar I gather but these were sold as systems so may not come up alone.
    P.S. The output gain on the 34 was adjustable, so it may be possible to customise it that way?
    I thought so too. The 34 has a sound that will never offend, but I just didn't find it very exciting.
    Looking for Quad 66 or 77 pre's reveals none for sale, unfortunately.
    My stuff -
    Would you be happy to take a look, should I go down that route, Alan ?
    My stuff -
    Yes no problem.
