Results 1 to 10 of 15
Thread: WTD: Pair of balanced XLR cables
    Default WTD: Pair of balanced XLR cables
    Nothing pricy or exotic, just neutral and transparent please. 1m ideal, could go a little under or a bit more over. Say 80cm-150cm.
    I'm Clive.
    I’ve got a pr. of 1m Chord Shawline XLR interconnects available for 150 incl. despatch (The were 250 new) in 1st class conditions.
    SOURCE:Cyrus Phono Signature+PSX-R2,Cyrus StreamX Signature,OPPO UDP-205 BluRay, SkyQ, Technics SL1210M5G/Achromat/MN Bearing/Isonoes with Boots/Origin Live Encounter Mk3A/Ortofon Cadenza Black or Hana SL or AT33PTG/II
    DAC: Chord Qutest, Chord Mojo/Poly
    AMPLIFIER:Bryston BP17-3 Pre & Bryston 4B3 Power
    SPEAKERS: Spendor D7.
    HEADPHONES OPPO PM-1 with Atlas Zeno cable, B&W C5 v2
    CABLES: Analogue: Speaker - Chord Signature. Interconnect - Atlas Mavros XLR x2, Chord Indigo Plus XLR, Chord Indigo Tuned Aray
    Digital: Atlas Mavros Ultra, Missing Link Binary Star, Chord Optichord.
    Mains: Chord Power Chord x3, Homemade SupraLoRad 1.5/MK/Wattgate x3, IsoTek Orion 6 way, Sounds Fantastic 6way Mains Blocks.
    STORAGE Synology DS216J NAS with 2 x 3Tb WD Red hard-drives.
    TV LG55B7 OLED
    Thanks for the offer I should have said, I'd like to pay about 20-30 but could go a bit higher for something nice. Unfortunately 150 is quite a bit over what I can afford.
    I'm Neil.
    There are many Belden or Canare Star Quad and Neutrik pro audio cables (like studios use) out there for that budget. Mark Grant do some, Blue Jeans cables are excellently made and low priced. You will not hear a difference between XLRs properly made, fact! It is a well-sorted interface.
    http://www.bluejeanscable.co.uk/stor...udio/index.htm
    Mana Acoustics Racks / Bright Star IsoNodes Decoupling >> Custom Silent Media Server >> Halide Bridge USB (with AQVOX USB power) >> Pedja Rogic's Audial Model S DAC + Pioneer PL-71 turntable / Vista Audio phono-1 mk II / Denon PCL-5 headshell / Reson Reca >> LFD DLS >> LFD PA2M (SE) >> Royd RR3s.
    I have bought several cables from this company in Nottingham. Good materials, good workmanship, fast turnaround for custom cables
    https://www.designacable.com/musicia...atch-lead.html
    Geoff
    Thanks guys these are the ones I've been looking at but thought it's check here first, if nothing comes up I'll buy new.
    You'll get some for a few pounds online and you won't be able to hear any difference, it'll just make you think you can the more you spend.
    Quote Originally Posted by vintagesteve View Post
    +1 There is no need to spend any more than 20 for a 1 metre pair.
    Have you listened to this month's choice in the Album Club?
    My chief consideration is whether to go silver plated or not. As the power amp has enough treble already I'm thinking not.
    What has silver plating got to do with treble on an XLR?
    Go for the cheapest well-made cables. My choice for 1m would be the designacable quad cable.
    Geoff
