16 will be plenty to start with then you can alter if its not right. i use menthol 20mg at moment but often just use the 16mg
Kik stuff is good and well priced
I'm Slav.
Any particular brands , I'd like to start with tobacco taste ?
I missed second line of your reply , thanks
I'm Slav.
Ordered thanks for the advice
It is entirely dependent on the vape unit. For example, 18mg will be fine on a ‘clearomiser’ pen vape like Geoff shared, but will be very very harsh with the bigger tanks, where 6mg or even 3mg is more appropriate.
Also with a pen vape you do not want a high VG juice as it is too thick, at a minimum 60/40 PG/VG ratio.
Think I used 6mg with my tank and could have been doing with less so agree Neil.
Think he was getting a pen type
I'm using 3mg with an Eleaf MTL tank and an Aspire Archon mod. Honestly I can't get even the vaguest hit, and I used to smoke marlboro lights. I think a change to a decent DTL tank and stronger liquid is on the cards. 2nd week vaper, 25 year smoker, though only a couple a day.
Mac72, the tobacco taste stuff doesn't. it tastes like stale dumps scrounged from the ashtray.
