I'm Paul.
If you wanted to dabble for little cost buy a half decent Lindy cable with the shortest length that you can and compare to a longer standard cable. At worst you are likely to have a cable with better contacts and better mechanical fit than the standard offering, not a bad thing for a cable that could potentially be fitted and forgotten about for a long time.
You’ll be surprised what a tarnished contact can do on a data cable.
~Paul~
I'm Peter.
Geoff,
Never a doubt in my mind, “especially with digital RCA cables”.
However, I relegated all that cable stuff and gone direct streaming via Roon Sever to a MicroRendu and usb to my Mytek Brooklyn. (With the usual analogue RCA Connection to the Amp.
Bloody Fabulous.
Peter
I tried a slightly expensive 'Atlas' USB cable for a giggle. Didn't find it a jot better than my usual Belkin or Lindy cheapo models.
Generally I find Lindy to be great quality at a great price for all my cable needs (I also have a fair few video type ones from them...)
I'm Dominic.
Once had a brief play with a JIB Silver Arsenic USB cable and it was only brief with an £800 price tag. I don't normally dabble in streaming and such-like and as far as USB cables go I was firmly in the 1's and 0's camp thinking there is no way a USB cable can alter the sound for the better. Couldn't have been more wrong, it transformed the sound and if I was more involved with the digital aspects I would consider looking into upgrade USB cables for sure. Maybe not 800 notes worth!
CD player = Marantz CD6006
DAC/pre = Rotel RC 1572
Power amp = ADA PF201
Speaks = Quadral Chromium Style 6
For me, USB cables can and do make an audible difference, but the question is "how much do you have to pay to get better sound quality?" Sadly, I don't think there's much relationship between price and performance here, but my £60 Kimber is audibly better than an inexpensive and supposedly genuine Belkin cable that I bought specially for the North West Audio Show. I'd be open to trying other USB cables out of curiosity, rather than intent to buy.
That is the issue for me Hugo.
It is the price relative to the performance gain of 1's and 0's arriving at their destination unharmed.
I can understand that removing the power from the cable may be beneficial for audio use, but I can do this with insulation tape if needed.
Kevin
Getting those 1’s and 0’s to your dac unharmed is a tougher nut to crack than many assume it is.
From personal experience USB isn’t the best way to connect to a Dac, the better (read: more expensive) cables sound better as they better mitigate the inherant problems with USB transfer.
USB cables can sound different..but I’d avoid USB if you can.
Sometimes if your using a laptop or PC its unavoidable, in that case I’d buy a USB to coax converter, the best one Ive heard (and owned back in the day) was a Musical Fidelity VLink 192.
AC POWER
AMPS
SPEAKERS
Wharfedale Evo 4.4
DAC
TURNTABLE
PHONOSTAGE
DIGITAL
MUSIC PLAYBACK
Ipad Roon Remote.
SPEAKER CABLES
INTERCONNECTS
I'm gone.
