Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Caiman SEG making painful noise when changing source or album
    I'm Tony.
    Default Caiman SEG making painful noise when changing source or album
    Hi all... I just wanted to check if this was a known problem before I trouble Stanley with it. When I change to a different track or album (streaming through Airport) I get a loud crackly fizzing noise. Even louder if I am using my Apple TV and changing videos on Youtube or something. It is fine once playing... it is just that second before kick-off it makes a terrible sharp noise. Is this a fault? Should it mute itself till it syncs in to the new track or source? Anyone else had this?
    Thanks all
    Tony
    Quote Originally Posted by Phonostage Records View Post
    Thanks all
    Tony
    I have the same problem and reported it but did not really get an answer. It is a nasty digital "spitting sound" which kicks in when switching between bitrates.
    Geoff
    Sounds like it's dropping the lock.
    On the Apple TV and Airport Express the signal is dropped by the Apple product in between tracks or TV channels. I am not sure why Apple is doing it that way. The SEG will then end up hunting for the signal in order to find it again, or to see if it has changed frequency.
    I myself can't emulate this fault since I avoid MAC products like the plague. But I shall modify one of the Sound Signature options in the Firmware and dedicate that to this kind of timing issue.
    Quote Originally Posted by StanleyB View Post
    thought that would be it.
    I am experiencing the problem with my Rpi/Digione. If my playlist includes a mix of 44 and higher bit rate files, the switch is accompanied by the spitting sound.
    A firmware update would be very welcome as I am otherwise very happy with the SEG, especially since the cap upgrade.
    Geoff
    I'm Alex.
    It's a shame that manufacturers like Stan have to modify their perfectly good products to run with flawed implementations from other products (sic Mac)
    I'm Tony.
    Geoff
    Hi Geoff, yes that is the same symptom, I could live with it for spotify etc but it is really loud when I attempt to use the Apple TV. The set up is sources streamed into an Airport Express then optical from the Airport to the DAC
    You’re not using an Airport Express by any chance are you? Just seeking to eliminate that from my enquiries
    Regards
    Tony
    Regards
    Tony
    No. I think the problem is about bit rate changes. The SEG does not mute when switching.
    I don't have this problem with my M-DAC and the Rpi/Digione.
    Geoff
    I'm Tony.
    Hi... ok thanks very much. I will contact Stanley and see if he is aware of it and also ask if this is the kind of thing that could be controlled using software.. ie some sort of delay written in to the audio output so there is a second or so of silence if you change anything.. or would some sort of relay be needed to acheive this (you can tell I am no engineer!)
    Thanks
    Tony
