Page 11 of 25 FirstFirst ... 91011121321 ... LastLast
Results 101 to 110 of 243
Thread: Amplifiers! What do you have? What do you use?
  1. #101
    I'm richard.
    Quote Originally Posted by hifinutt View Post
    yes , currently doing good service with FB mono`s . when and if i upgrade i will keep as back up as its rather good . i was listening to an album the other day and nearly jumped out of my skin on one track as it was very good . The FB are extremely transparent and revealing of any poor recordings. My MSB is a bit more forgiving !!!
    Schiit Saga is definitely underrated in the UK as far as I can see; as is the Freya. Bit of a bargain I'd say.
  2. #102
    Main amp: Classé Model 30 / Luxman M-383
    AV: Onkyo TX-NR636
    Computer Room: Sony AV amp of some description!
    Littering the spare room are:
    A&R Cambridge A60
    Inkel PD-1100 / MD-1200
    Sonab R3000
    John Shearne Phase 3
    There's also an old wooden amp that I can't remember anything about, will have to dig it out.
    Nottingham Analogue Spacedeck / Kuzma Stogi S / Benz Micro Ace S L
    Lenco L-75 / Carl Ellis Plinth / Ortofon AS-212 / Ortofon SPU Classic GM E MkII
    Ortofon ST-7 SUT / Nick G Modded Lentek Head Amp / Croft RIAA
    Cambridge Audio CXU / Theta DS Pro Prime
    Usher Compass X-719
    May contain opinions that others find disturbing.
  3. #103
    I'm Clive.
    In my system I have a Kinshaw Perception pre amp to go along with 2 Kinshaw Perception SA phono stages.
    Also use a Nakamichi CA5E as both a phono stage and second pre amp.
    My power amp is a Lumley Reference ST40.
    As backups I have a non matching Rotel pre and power but not used much.
  4. #104
    Quote Originally Posted by Smegger68 View Post
    Probably a tree-ode design.
  5. #105
    I'm Deleted.
    I use a combination of Paradise, Naim and Lab.gruppen.
    Pre-amp is a heavily modified Naim Nac72 (all circuit boards are replaced by those from Ryan Sound Labs). The 72 is powered by a modified Naim Hi-Cap (Avondale TPR4 regulator circuit and Kendeil reservoir capacitors). This feeds a pair of Naim Nap135 monoblock amps (stock except for Kendeil reservoir capacitors). The bass drivers are independently powered (in active configuration) by a Lab.gruppen ipd1200 - this also does some DSP. The phonostage is a four box Paradise.
    Account Deleted
  6. #106
    I'm Jayson.
    Musical Fidelity AMS 35i
    Musical Fidelity AMS 35i / Electrocompaniet EMC 1UP / Transrotor ZET 3 + Konstant M1 Ref. psu / Jelco TK-850S / Hana ML / Bigbottle mk3 phono stage / KEF Reference 3 / Auralic Mini / Chord Qutest / Isotek Aquarius / Sbooster mkII psu
    Mains cables: Viablue X40 mains cable + Furutech NCF plugs + SR Orange fuses
    Speaker cables: MIT AVt MA
    Interconnects: MIT AVt MA / MIT Matrix 12 / Zavfino Majestic tonearm cable
    USB:Curious
    Rack: Solid Tech Hybrid
    Accessories: IsoAcoustics Orea Indigo + Bronze / Gaia II / SDS soundeck
  7. #107
    I'm Ian.
    Main system is a Nakamich CA 5E pre amp only used for it's excellent phono stage running into a Musical Fidelity A3.
    Computer system is a Nytech CA202.
    Turntable
    CD
    Network Player
    Cambridge NP30
    Amplifier
    Speakers
    Cables
    Headphones
  8. #108
    I'm sorted.
    Main system I switch between valves & solid state - JE Audio VM60 / Quad QMPs (simply because I can't make my mind up which monoblocks I prefer - both types have their virtues)
    TV duties - Yamaha R-N301 Receiver
    Conservatory system - Kenwood KA-1030 Integrated
    Bedroom system - Pioneer SX-757 Receiver
  9. #109
    Main system - Copland CSA29.
    PC system - Denon PMA 250 II.
    Son has borrowed - NAD 3020.
    Doing nothing - 2 x T amps, a TDA2030A dual mono diy and 3 x TDA7297 stereo chip amp also DIY.
    Boothroyd Stuart Meridian 101 with MC and MCA pre amp.
    Steve.
    Kit I have:
    CD player, TTs, Phono stages, Pre amps, Power amps, Integrated amps, DACs, Streamers, Speakers and a bunch of cables.
  10. #110
    I'm Shaun.
    Currently using a Prima Luna Prologue Three preamp into a Prima Luna Dialogue Premium power. Still using the original EL34 power valves however even though I have owned the amp since 2016 it hasn't had a lot of use, in fact, I'd say less than 1000 hours.
