Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: How best to connect my sub to amp?
  1. #21
    Andy, I have pondered thus question too and although your sub woofer is not a REL have a look on their website as they have some very clear instructions on how to connect a sub to an amp and set it up.
  2. #22
    I'm Gary.
    I havn't looked at the REL site, but it may refer to high level inputs (basically using the speaker terminals) you don't have this option on your sub as far as I can see, so don't let it throw you.
  3. #23
    I'm Andy.
    I've installed the sub now, thanks. I just got a stereo 2x phono to 2x phono cable from the local sound and lighting store and have connected it mono with a single terminal either end. I've spent about an hour fiddling with the dials but I've got it sounding pretty good to my ear now.
  4. #24
    I'm Alex.
    In agreement with other comments, adjusting crossover point of the sub and levels with main speakers is a time consuming process. It is also dependent on the sub placement and room interactions with bass nodes. I find that a good sub setup fills in the lower registers and does not intrude/congest the mid-range. Personal preferences of course...
