Results 11 to 20 of 24
Thread: How best to connect my sub to amp?
    Point 1. Sub 1 or 2 will work, so the answers yes.
    Point 2. Some amplifiers have pre outs to feed a seperate power amp. The internal power amp is still connected. That is what's suggested in the second diagram. On the NAD there is a jumper that feeds the pre amp to the internal power amp but by using this you disconnect the power amp therefore the main speakers.
    Hope that makes sense.
    Gary
    Yup. That's my take too
    I agree with Gary, you can use just one lead to either the left or right on the sub. I've done that in the past and that works fine. Leads tend to come in pairs though.
    You can't use the pre out.
    I'm nigel.
    Remember......you should not be able to hear the sub....at all.
    To little output is MUCH better than too much.
    If its up too high, it will impress at first, but trust me, after a while you will notice the bass dragging the impact and speed of replay back.
    Get a friend to sit in your hotseat and listen while you twiddle (ooh err missus etc), your back will thank you.
    I'm Gary.
    Sub leads come as singles ( no difference in construction to normal RCA's though) and are generally longer than normal RCA's to let you place the sub where you want. To a degree you can place the sub anywhere to suit your setup.
    I'm Andy.
    Quote Originally Posted by sumday View Post
    Yeah I don't need/want the sub up high. It'll hopefully just be a little extra meat to compliment the brightness of the 902i's. Thanks for the advice.
    I'm Andy.
    Gary
    Yeah it makes sense, cheers. I knew that the NAD came with external jumpers connecting the pre-out to the main-in, whereby removing them cuts sound output to the speakers. That's why I was confused by the connection guide in the sub's manual — I didn't think it would work that way.
    I'm Alex.
    Is ther a filter on your amplifier's sub-out. If not, your main speakers will be running full range, so you will need to adjust the crossover point on your sub and match level so that the bass is not overwhelming the sound from your speakers
    I'm Andy.
    Quote Originally Posted by maxrob200 View Post
    The speakers are rated to 55hz and the sub 34hz with crossover controls from 50hz to 150hz, so I set the controls to 55hz, right? This instructs the sub to only play bass sound that my speakers are unable to reproduce?
    I'm Gary.
    Quote Originally Posted by ciderman9000000 View Post
    It's a starting point, you have to use your ears. Try setting the sub to 55hz and turn the sub volume till its intrusive, then back off the volume slowly till the sub disappears. The speakers may not output to 55hz tho so you may have to play with that setting.
    As has been said before its time consuming but worth getting it right
    Gary
    Gary
    That's right. Basically, disregard the figures and listen to what the speakers and sub are doing. It will become evident what settings work best.
