Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: Question about TIDAL
  1. #21
    I'm Simon.
    Quote Originally Posted by WESTLOWER View Post
    the latest version of Roon, also deals with Tidal's MQA (masters) so the compatible DAC isn't an issue In this case, I believe.
    Edward should be along shortly to clarify...
    I believe Roon (1.5?) only provides the first unfold (i.e. same as Bluesound via digital). You still need a compatible device for the full unfold.
    Perreaux DP32>Perreaux 100p>Scansonic MB-1 speakers.
  2. #22
    I'm Adam.
    Quote Originally Posted by simon g View Post
    Understood, although it sounds darn good to these ears.
    Begs the question how 'high res' does one want to go and is high res 'better' than Red book?
    "lack of passion is fatal"
    Gerrard 401, classic hifi hammertone, Russ Collinson plinth / Tenuto Gun Metal Turntable Mat / SME 3012 J7 Rewired / audio-technica ATP-12T - phonomac modified / Ortofon Vintage SPU GE /Shure M3D /DV XX2Mk2 / The Cartridge Man Music Master with isolator / Miyajima Zero B 0.7mil Mono / Vintage GE VRII Mono / WAD 300b Power modded, TJ Mesh Plate Valves / David Coe AD Audio 'Satchmo' Pre & Phono / Hashimoto HM-7 SUT / Tannoy 12" MGs in RFC Custom Rutland Cabinets with RFC Custom Crossovers / Speaker Cables: Duelund DCA16GA Tinned Copper / SW1X Audio Design USB-SPdif / SW1X Audio Design DAC 1 Signature / Interconnects: Duelund DCA20GA home brew /SW1X Audio SPDIF AERO 6 / Synology NAS Drive / Roon / Tidal HiFi / Mains Power Conditioner
  3. #23
    I'm Neil.
    I have a feeling that there is some good remastering going on with MQA releases.
    Redbook *is* high res. It is concerning that the market is being lead to believe that 24/96 is better, or DSD, or MQA.
    If you listened above 100db (Redbook is 96db dynamic range), and the mastering could take it, you might get a smidgen of benefit from 24/96, but you’d have hearing damage pretty quickly.
    For the foreseeable future CD will be my preferred format, and don’t think anything is going to replace 16/44.1 soon, even if only for filesize reasons. Apple etc. like to save their bandwidth.
    Mana Acoustics Racks / Bright Star IsoNodes Decoupling >> Custom Silent Media Server >> Halide Bridge USB (with AQVOX USB power) >> Pedja Rogic's Audial Model S DAC + Pioneer PL-71 turntable / Vista Audio phono-1 mk II / Denon PCL-5 headshell / Reson Reca >> LFD DLS >> LFD PA2M (SE) >> Royd RR3s.
  4. #24
    I'm Edward.
    Only the desktop application version of Tidal will do the first unfold of MQA. Unfortunately google cast (aka Chrome Cast) is not yet integrated in the Tidal application. So if you use a Chrome Browser to try cast to a device no MQA unfolding will occur and hence will default to the lower setting (i.e. HiFi).
    Roon, as Adam mentioned, at its latest version (1.5) will do the first MQA unfold (to 88.8khz/24bit) and output in PCM to any dac capable of that resolution (or higher). I need to check if Roon can Chrome Cast but I don't think it can (suspect that Roon Labs won't be pleased with the latency).
    My recommendation anyway is to get Roon (with Tidal enabled) and get a Roon endpoint (e.g. a NUC) so you have the best of all worlds (Master quality everywhere in your house, Tidal albums integrated with your own albums, remote control [from say your phone/tablet], deep metadata and much more besides.) The Roon digital transport mechanism is second to none (IMO). With MQA (1st unfold) enabled the sound has become even more supreme (but of course depends on the original recording).
    Edward (aka Roon Fanboy)
    Source: Tidal/Roon
    DAC: Metrum HEX NOS
    Amp: Sugden Masterclass 2018 spec, Radford Revival STA25,
    Speakers:, Tannoy Eaton
  5. #25
    I'm Adam.
    Quote Originally Posted by Edwardlon View Post
    You on commission Ed?
  6. #26
    I'm Edward.
    Oh I wish.
    Just had a look at the Tidal app available for my phone (an Android) and see Master MQA not available. I guess as a more powerful CPU is needed.
    Via Tapatalk
    Source: Tidal/Roon
    DAC: Metrum HEX NOS
