reduced to £2500
reduced to £2500
Musical Fidelity AMS 35i / Electrocompaniet EMC 1UP / Transrotor ZET 3 + Konstant M1 Ref. psu / Jelco TK-850S / Hana ML / Bigbottle mk3 phono stage / KEF Reference 3 / Auralic Mini / Chord Qutest / Isotek Aquarius / Sbooster mkII psu
Mains cables: Viablue X40 mains cable + Furutech NCF plugs + SR Orange fuses
Speaker cables: MIT AVt MA
Interconnects: MIT AVt MA / MIT Matrix 12 / Zavfino Majestic tonearm cable
USB:Curious
Rack: Solid Tech Hybrid
Accessories: IsoAcoustics Orea Indigo + Bronze / Gaia II / SDS soundeck
bump...Granite plinths(1.5in.thick) now included in sale.
USB:Curious
Reduced @ £2475
USB:Curious
still available. offers?
Tech specs:Type: 3-way vented floor standing speaker, Powerflow
- Drivers: Two 6 1/2" (16.5cm) "W" woofers, 6 1/2" (16.5cm) "W" midrange, 11/4" (27mm) pure Beryllium IAL inverted dome tweeter
- Frequency response (+/-3dB): 34Hz - 40kHz
- Low frequency point (-6dB): 28Hz
- Sensitivity (2.83V/1m): 91.5dB
- Nominal impedance: 8Ω
- Minimum impedance: 3.5Ω
- Crossover frequency: 350Hz / 2200Hz
- Recommended amplifier power: 40 - 300W
- Dimensions (HxWxD): 43 11/16x10 3/8x13 3/4" (110x264x350mm)
- Net weight: 72.6lb (33kg)
USB:Curious
Now reduced to £2350
USB:Curious
bump
USB:Curious
bump
USB:Curious
bump
USB:Curious
bump
USB:Curious
bump
USB:Curious
