Results 1 to 10 of 11
Thread: FS: Passive preamp, Pass B1 R2 with built in MM phono stage
    Default FS: Passive preamp, Pass B1 R2 with built in MM phono stage
    For sale, my passive preamp using the Nelson Pass B1 R2 complimentary JFET buffer design, direct coupled with no capacitors in the signal path.
    http://i.imgur.com/byuvtHa.gif
    Two box construction with dual low noise shunt regulated power supply, preamplifier and screened umbilical connecting cable.
    The preamp uses a complimentary pair of matched Toshiba JFETs, a quality Swiss Elma selector switch and 100K stepped attenuator with Dale resistors. The inbuilt MM phono stage is built on an Elliot Sound Products phono PCB and uses a pair of AD823AN jfet input opamps.
    The preamp has one phono input, three line inputs and an earth binding post for the phono stage. Gold plated RCA input and output sockets with PTFE insulation. Silver plated PTFE insulation signal wiring.
    I'd like £185 plus RMSD postage at cost.
    lordmortlock Guest
    You make some lovely things Martin. I wish I had just a hundredth of your talent!
    Quote Originally Posted by lordmortlock View Post
    +1 Beautifully built and presented. Well done Martin.
    I don't expect this will hang around for long. GLWS
    Thanks!
    Major pre-amp bargain here. Looks great!
    too true.
    PM sent
    Cheers
    I'm Nat.
    Well done! What a fantastic looking amp.
    If Steve hasn't already snaffled this, I'd be interested too 😀
    Bigman80 Guest
    Join the queue. I'm 3rd in line!
    Quote Originally Posted by Idlewithnodrive View Post
