Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: Repair, leave as is or replace Valdus centre speaker?
    I'm Joe.
    Question Repair, leave as is or replace Valdus centre speaker?
    As part of my home theatre setup I have a Wharfedale Valdus Centre speaker. (back in the day they didn't look pretty but what was saved on looks was spent on sound as it was a pretty good centre for the money.) It has served me well for over 20 years now. I moved house last year and in the move the rubber surround on one of the speakers got damaged. Basically it has become sticky and in the move the grille got pressed against it. So when I removed the grille to see what the sticky stuff was, it pulled a hole in the rubber surround.
    I've still be using it for the last 10 months or so and it doesn't seem to have affected the sound. But the anal part of me knows that there is a "non-perfect" driver behind the grille..... To get a new driver from Wharfedale would be about 60 quid to me. Equivalent shielded ones on eBay/ Amazon work out to be about the same cost. And the speaker cost me about 130 over 20 years ago. So then I said for that money I may as well upgrade it...….and I was about to buy a Dali Zensor centre to match my main stereo speakers, but with my room I can't really fit a bigger (deeper) centre speaker...
    So leave it alone?
    Replace the driver?
    Or are there better small centres out there?
    (I know that the front 3 should be the same make/ model for tonal balance, but to be honest, I've never really found an issue for movies with them not matching)
    Any opinions? Suggestions?
    Have you tried doing without the centre speaker? De-select it on your amplifier and it will split the centre channel signal between the two main front speakers. I prefer this to using a separate centre as do a number of people.
    If your not keen on that I'd agree replacing the driver is not cost effective. Trouble is decent centre speakers tend to be pricey for no real reason. Even used ones. But if you can find another Valdus centre on eBay or somewhere it shouldn't cost more than fifty quid.
    Agree that there's no need to have matching speakers all round unless you are using the system for multi channel music as well as films. Even then the benefit is slight unless the mis-match is extreme.
    I'm Adam.
    Why don’t you replace the surround? Most places that sell foam surrounds also sell rubber ones.
    I'm Hugh.
    This /\
    I'm Joe.
    Good suggestions on both points. I never thought of replacing the surround or just looking for a complete second hand Valdus..
    I'll also try the system set to just 4 speakers and see how it sounds. Cheers.
    I'm still in the camp of QUALITY centre-speakers making a significant difference. Unfortunately Joe, a Valdus doesn't really qualify as such. I had one once. It's ok. but very much at the budget end of things.
    Therefore, if you can't afford to spend more, I'd stick to the advice you've been given. However, what front speakers are you using? I've got vintage Celestion 15XRs, as fronts, and simply a single one of those performing the role of a centre speaker, which I've also re-capped along with the fronts.
    It works a treat (really adding depth and clarity to vocals and explosive effects), and only cost £30! Good vintage speakers can be the way to go in a home-cinema system, as if you shop around they can be much cheaper than modern options. Plus, the less 'in yer face' voicing/sonic presentation is arguably more suited to today's movie soundtracks
    I'm Joe.
    Oh yes I know it is definitely budget even when new. But it was best of the crop at that price range. And it has served me well. My mains are Dali Zensor 5s. I was about to buy a Dali Zensor Vokal to replace the Valdus, but when I measured up, I simply don't have the room to fit a centre that deep. So the Valdus was kept. I can go wider and higher, but just not deeper.....
    I have fairly new Wharfedale Diamond 9s in a box in the attic, I could use one of them. But is the issue of shielding around amps and telly no longer an issue?
    Or else I will look for some better class of older speaker but that fits.
    Magnet shielding is not an issue with modern televisions. It was with old CRT screens, where the internal mask could be affected.
    As for centre speakers, some might say they just add information for image placement and all that is required for this is the directional information in higher frequencies, not full range audio. Many years ago, there was a Hafler circuit enabling a tweeter only to be used centrally between two stereo speakers to 'fill the gap' as it were. This worked, I tried it. Unfortunately, it also adulterated the true stereo image separation, as does any centre speaker.
    Regardless, as movie soundtracks are artificially created, good ones in my experience can definitely add something beneficial to the overall experience, plus add an extra dimension to the reproduction of 5.1 music Blurays/DVDs.
    I wouldn't be without my centre speaker
    I suppose there is another way of looking at this. You could have one huge central speaker covering the full audio bandwidth and two small speakers, one each side. Bass is said by some to provide little directional information (not sure I agree mind you), so it could emanate from the middle, whilst the directional cues could come from each small side speaker.
