Page 5 of 10 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 94
Thread: DSP active crossover
  1. #41
    I'm Edward.
    Quote Originally Posted by Magna Audio View Post
    Won't comment on the Jriver side of things not used it as X/O, do try lower than 4 order though.
    I've found 4th order okay on sub horns and mid bass but further up the frequencies it kills feeling / mood - very driver dependant I guess. If they are good quality you want to let the loveliness play on a bit.
    Thanks Steve. This is precisely why I'm attracted to try active dsp, the ability of being able to adjust things easily and immediately hear the differences. In addition to trying different slopes I will be trying out different crossover points starting at what the passive crossovers are.
    Room correction will add another dimension.
    My fear is that this will all become too good leading me to having to get high end and expensive multichannel amps such as what Ken is currently doing.
    At a recent show I went to there were some 3 way Kudos Titan speakers being actively driven with multiple Linn amps. Shockingly good.
    But I dare say not as good as your Tannoy GRF recipes. When I win the lottery I will be over to you and Paul's (RFC) to discuss a bespoke Tannoy system. Until then I will have to slum it with the Eatons.
  2. #42
    Hehe, you haven't heard my 5 way system yet
  3. #43
    I'm Edward.
    No indeed I have not heard them but I have heard of people who have heard your 5-way horn system. (there I got 'heard' in 3 times ).
    Did dip into your WAM thread and could only dream of having your skills - particularly your woodworking skills.
    What are the dimensions of the room you have your 5-way system is btw?
  4. #44
    It's a loft room.
    5m wide and longer than needed.
    I sit about 3.5m away.
    They've come on a lot since the Wam thread
    DSP is great for that flexibility. So easy to try different settings and if you change driver impedance no problems
  5. #45
    I'm Edward.
    My wife and friends keep bugging me to convert a dead space I have. If I did the space would be about 6.4m by 3.1m with 2.3m height. Seems ideal ...
  6. #46
    I'm Gordon.
    Quote Originally Posted by Edwardlon View Post
    Hi Gordon
    Appreciate if you could have a look at the following screenshots and let me know if I have got it right.
    My plan is to have the normal L/R channels mapped to the bass drivers, the surround L/R channels mapped to the midrangers and the Rear L/R mapped to the tweeters. I have used the passive crossover points of 800hz and 5,000hz. Will start with a 4th order (24db) slope. Once I plug things in I can adjust from this baseline.
    What I'm not clear about at this stage is what negative or positive gain I need to apply to each channel to start with? Or will I just derive this by trial and error later on? What did you do?
    Cheers
    Output Format
    Copy Channels
    High Pass Filter
    Low Pass Filter
    Sorry about the late response - been busy with watching footie too, plus my son is on a charity trip to Peru - he spent the evening in a bar in Lima airport watching the England/Colombia game - in a bar full of Colombian's everyone very friendly so no problems... he's finally got to his destination up in the mountains safely, so all is good.
    Anyway, looking at your screenshots my first question is regarding your output format - is there a reason you are using 2 channels in a 7.1 container rather than using 5.1 channels as you have 3-way speakers?
    The x-overs look fine, although I would have routed Left,Right for bass, Centre,Sub for mids and SL, SR for highs. However if what you have setup works for your routing it doesn't really matter. Like Steve (Magna Audio) I wouldn't recomment a 24db/oct Butterworth either. But I would use a 24db/oct Linkwitz-Riley which sums flat. JRiver can't do Linkwitz-Riley filters natively, but as they are just cascaded Butterworths all you need to do is create two 12db/oct Butterworths and you have your 24db/oct Linkwitz-Riley.
    If you know the driver sensitivities then I would just take a rough guess at setting the most sensitive ones down a few db.
    I may have missed it in your earlier posts but what DAC are you using to get the signal from JRiver to your amps?
    Hope this helps.
  7. #47
    I'm Edward.
    Quote Originally Posted by Halfway Tree View Post
    Ah yes I know Lima and Cusco well. We went there about 3 years ago to visit our daughter who was spending 6 months there. Very friendly people and great food (not the guinea pig though!)
    Just going with JRiver's recommendation. Don't want anyway to get confused with the sub (as per in x.1) so aiming to just use 6 of the normal 7 channels.
    Any particular reason you would route things in that way? My rationale is just to skip centre and sub due to them not being L or R. And anyway surely the sub on an AVR is pure line level without ability for filtering, attenuation etc? Naturally I will have to actually map what I've set in JRiver to the actual channels on the amp.
    How do I cascade the Butterworths by creating another filter?
    I'll give the tweeter -4db, mid -2db and go from there. I imagine that later on when/if I do a room correction filter then that filter will adjust things appropriately.
    To start with I will be using a Xonar 7.1 dac. Not the state of the art, but remember this is just a 'proof of concept' project.
    Hope this helps.
    Yes it really does Gordon and I very much appreciate your time/help.
    The AVR amp was meant to arrive today but no sign of it. I hate having to wait around or depend on neighbours.
  8. #48
    I'm Gordon.
    Just been looking at the Xonar 7.1 Dac - it seems to have 5 analogue outputs - Front L, Front R, Side, Centre and Rear - I'm probably missing something here, but how do you get the 6 channels you need out of it?
    I'll grab a screenshot of Linkwitz-Riley crossover in JRiver.
  9. #49
    I'm Gordon.
    Here's a screenshot of a 120Hz L-R 4th order (24db/oct) using cascaded Butterworth's in JRiver. The 12Hz high pass which is also a L-R 4th order is simply there to provide some protection for the bass drivers. You can create a L-R 2nd order simply by cascading two 6db/oct Butterworth filters. I use a 2nd order in my Linkwitz LX521s between the lower and upper mid drivers.
  10. #50
    I'm Edward.
    Cheers Gordon
    I think I see the logic of how you cascaded things. Thanks.
    The Xonar outputs of Side and Rear are 3.5mm stereo pairs so with the FR and FL plus mono CTR you get to 7 channels.
    AVR arrived. Yet to check operation. Huge transformers so quite weighty.
    Next thing to do is to break the rear seals on the speakers and then rewire to 6 speaker posts (3 x 2) each speaker. I was thinking of having 8 posts each speaker with a suitable switch so I can readily go from active to passive. May do that later on. I'll leave the passive crossovers in-situ for now.
