Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: System improvement options
  1. #21
    Fair point, things got a bit sidetracked as usual.
  2. #22
    I'm Justin.
    Quote Originally Posted by SantanaCorreia View Post
    I do also find the Audiolab to be very flat. Maybe sometimes a bit blend.
    The pairing with the MA works wonderfully for jazz. When it comes to rock is not that good. Almost all my friends agree with me. Also works wonderfully with fado, but many of you dont know it so it is not a refrence.
    With indie, the music style I listen the most, I would prefer a bit more bunch.
    Anyway I believe the system should play everything well and not just one music style. Dont want and dont need that kind of handicap.
    I will try to audition that creek. Is it a new one or an older model?
    Anyway I was trying to get some excit
    Enviado do meu HTC_M10h através do Tapatalk
    Hi Luis, please let us know what amplifier you try with your speakers, I’m very interested in the outcome. Thanks
    Yamaha NP-S303 / Audiolab 6000cdt
    NAD D1050 dac
    Creek Destiny 2
    PMC DB1 Gold / KEF LS50
  3. #23
    I'm Luis.
    Well... Let me update this.
    Finding good used equipment has been quite a journey.
    For the new amp.
    I am between, right now, creek a50, a 100, naim 5i, naim 5si, primare i22, i32.
    I believe creek would give me the best result...
  4. #24
    I'm Robin.
    For the new amp.
    I have a Primare i32 and very happy with the sound
  5. #25
    I'm Luis.
    Quote Originally Posted by rmcin626 View Post
    Have you heard the i22?
  6. #26
    I'm Robin.
    Yes but the i32 is worth the extra cost, if you can afford it
  7. #27
    I'm Luis.
    What did you notice between the two?
  8. #28
    I'm Brian.
    If you can find an Audio Analogue Cresendo give it a try.
    I used a Nad C316, Arcam A18, Rotel, Valve Audio Exclame and the AA Cresendo on mine and the Cresendo really showed me what my Rx6 were made of...solid meaty bass great detail whilst never been bright, definetly more punch and weight to the sound and very musical.
    In the end I found the Rx6 are extremely sensitive to Bad recordings and very compressed recordings, I found they favor Jazz and Acoustic stuff more than the livelier stuff, I eventually sold them.
    Primare should also work very well.
  9. #29
    I'm Robin.
    Improved soundstage, better bass control generally everything a bit tighter. If the i32 fits your budget then you will be happy with it there is a bit of a price difference.
