Results 1 to 8 of 8
Thread: FrostEOne intro
    I'm Mark.
    Post FrostEOne intro
    Have 2 systems, one is solid state, other is vacuum tube. Direct drive S-arm turntable on both systems. Collection of vinyl from early 70's to mid 80's. Enjoy a wide range of music including rock, country, jazz and blues.
    Background: Automotive Machinist, Plumber, Electrician, Boiler Operator, Computer Technician.
    Recently retired which gives me more time for music enjoyment.
    Hi to all!
    Hi Mark,
    Welcome to AoS
    Sounds like an interesting system. I'm sure folks would like to hear more about it, in terms of what the actual components are. Also, if you have time, posting some pics of your system in our Gallery section would be great!
    Hello Mark. Welcome to AOS.
    Tell us what equipment you use in your two systems.
    I'm sure you'll find plenty to interest you here, so just join in.
    Enjoy the forum,
    Geoff.
    Hi Mark, welcome to the forum.
    I wish I was retired, it must be great.
    I'm Mark.
    Arrow Systems
    Thanks for the welcomes, here's a rundown on my 2 systems.
    Solid-state: Pioneer PLX-1000, Audio Technica VM760SLC, Denon TU-1500RD, Denon CD Changer, Adcom GFP-815, Adcom GFA-555se, CerwinVega CLS-215, CerwinVega XLS-15S
    Vacuum tube: (Pioneer PLX-1000, Audio Technica VM760SLC - borrowed from SS system), Yamaha YP800, Clearaudio - Performer V2 Ebony MM, JD9II Phono Preamplifier Level 1 Upg, JD9II Phono Preamplifier, Marantz 125, Fusion DAC Transport, Fusion 3000 Preamplifier, Jolida Fusion 3502P Power Amplifier. Yamaha NS1000M, SVS Dual SB-2000
    I stick a couple pics in Gallery.
    Welcome to AoS Mark.
    Yes being retired is the best way there is to listen to one's system and enjoy music for hours on end.
    Enjoy the Forum
    Barry (retired from electronics research)
    I'm Neil.
    Welcome to AoS
    Regards Neil
    I'm Mark.
    Enjoy the Forum
    Barry,
    I can usually get in 4 hours listening daily. Used to scrutinize my system a lot, these days I just listen and enjoy.
    Mark
