Results 1 to 9 of 9
Thread: KABusa SUPERFLEX tonearm wire.
    I'm jamie.
    Default KABusa SUPERFLEX tonearm wire.
    i just received mine today,very flexible and seems perfect for tonearms,it makes cardas litz feel stiff as hell.
    i know oli uses it but does anyone else?
    My System
    John Wood KT88 Amp.
    Paradise Phono Stage
    Sony TTS-8000 Turntable.
    PMAT-1010 MK6 Tonearm.
    Ortofon Cadenza Bronze
    Sony X555ES Cd Player
    Yamaha NS1000m Speakers
    Bigman80 Guest
    Phonomac too. It's in my PM-AT1010
    I'm Robert.
    Angus may have used it when he re-wired my Micro Seiki tonearm but i'm not sure to be honest
    My System:
    CDP - Pioneer PD-91
    Bigman80 Guest
    Unless you specified a particular wire I am sure he has. Like I found with the Mission 774 arm, the wet spaghetti feel of this cable offers no mechanical resistance in the arm and it's really easy to work with, just go easy if drawing it through, Jamie or you may rip the silicone coating. You also don't need loads of heat when soldering it as the silicone retracts quicky. Just my experience of it.
    I'm jamie.
    nice one,cheers for the tip,ive just re ordered to do the zeta as well.
    i did find that the zeta with cardas in it tended to be influenced by the wire,this stuff should be just the ticket.
    My System
    John Wood KT88 Amp.
    Bigman80 Guest
    No worries mate, glad you've decided to try it. Will anyone else give it a go? I've only been banging on about this wire for 3 years 🤣🤣
    Is it just the wire or has it been soldered into the back of a headshell socket.
    Alan
    I'm jamie.
    On my zeta it will be running straight into the cartridge.
    My System
    John Wood KT88 Amp.
    I'm loheswaran.
    Quote Originally Posted by karma67 View Post
    How was it to run straight to your phono/rca plugs as I am contemplating this
