Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Interesting Chinese field coil 13" driver.
    That one has bothered me for some time. I assume it is historic, as permanent magnets then were not powerful enough (i.e. could not produce sufficient flux density).
    However the power supply has to be very well smoothed, otherwise any residual mains hum would modulate the audio signal. Traditionally they ran off 100V and consumed a fair bit of power.
    The only advantage of field coils I can see is that you can vary the energising current, and hence the damping.
    How about back emf has less effect on magnetic field integrity and therefore is more accurate under normal operation.?? dont know, just asking
    Grant ....
    OPPO BDP-103D DARBEE - JBE SERIES 3/B&O SP1/EMOTIVA XPS1/12V BATTERY - TWIN PRO MONOBLOCK AMPLIFIERS - XIANG SHENG DAC\PRE\HEADPHONE AMP\WE TUBED - TWIN AVANTREE OASIS CLASS 1 BLUETOOTHS - AUDIO TECHNICA ATH-MSR7 & OPPO PM-3 PLANAR HEADPHONES - WIN10 JRIVER24, SPOTIFY - SMSL M6 MINIDAC - RPI/AUDIOPHONICS/5V BATTERY - FULL RANGE TWIN TELEFUNKEN/Q ACOUSTIC BT3/CANTON SUB - P.INSPIRED MAINS REGENERATED.
    I'm Alex.
    I suppose that one could Turbo the field coil, over voltage the coil, probably shorten it's life too.
    Spendorman
    Quote Originally Posted by spendorman View Post
    There is a 12" Magnavox field coil speaker in a very very old radio here.
    Is there any advantage of field coil units?
    I can't think why there should be. I think fans just like the 'aura' of a sort of exclusivity.
    I'm paul.
    The other products from this maker are well worth a look.
    Yes some nice kit, I have too many projects lined up already and not enough time.
    Sony STR 6055 Denon DP80 Stax UA-70 Shure Ultra 500 Zu omen
    Office system, DIY CSS fullrange speakers with aurum cantus G2 ribbons Najda dsp as dac Akai AM-U02 Jvc QL-A51 direct drive turntable
    SAE1000LT leema sub. JVC Z4S cart is in the house
    Garage system another Sony receiver, cassette deck and full range drivers in free air
