Thank you!
I'm Johan.
Thank you!
Photobucket no longer works unless you pay the hefty subscription.
If you want to try 'tinypic' http://tinypic.com/
I wrote instructions a while back. Here:
thats a lot of ipa,no wonder it drys fast!
My System
John Wood KT88 Amp.
Paradise Phono Stage
Sony TTS-8000 Turntable.
PMAT-1010 MK6 Tonearm.
Ortofon Cadenza Bronze
Sony X555ES Cd Player
Yamaha NS1000m Speakers
I use about 25% myself
A ratio of 1 (PA) : 4 or 5 water is pretty standard, and is suggested in that Jazz Collectors' link to DIY record cleaning fluid. Using a ratio of 1:3 is okay if you have a very soiled record. I've resorted to almost pure IPA on one or two charity shop records in the past, without any noticeable detriment to s.q. on playback.
One caveat mentioned at the beginning of that linked article concerned a 'using freezer water 'cos my physics teacher said it was the same as distilled water' Melted ice from defrosting the freezer IS effectively distilled. However, it should obviously be thrice filtered to remove any rubbish.
better with ilfatol. last u a lifetime
