Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: Help! Buzzing interconnects on a 1210GR
  1. #21
    I'm Gary.
    We're probably drifting off topic now, but it is interesting.
    Bend radius has an effect on signals, hence specifications of minimum radius in Cat xx used in computer networking, I don't know if it's relevant to the signals we are talking about here?
    I suggest if anyone wants to expand on this we start a new thread.
    Gary
  2. #22
    Bigman80 Guest
    Gary
    Can't imagine anyone will want to chat about that Gary
    Just joking, its way out of my remit.
  3. #23
    Sorry, I missed that. Yes, there's a layer of carbon loaded polymer next to each conductor. I don't know what it's for. The manufacturing process may make it easier to have it than not have it - I don't really know.
    Suspect it is to prevent tribolelectric charges building up through flexing/handling. Many hand-held microphone cables have a semiconducting layer under the brading, however the Carbokab cables would seem to be too thick for use with microphones.
    I have a pair of Sommer Carbokab cables wired for balanced use with XLR connectors. I found the presence of the carbon-loaded layer next to the inner conductors to be a nuisance: it has to be completely removed otherwise the conductors won't 'tin' properly.
    I'm Andy.
    Thanks for the advice all, I'll try a Mark Grant cable (as 2.5m seems very affordable) and see how that goes.
  5. #25
    I'm Andy.
    Change of plan - I've ordered the Rothwell Audio interconnects instead as I've not used those before. I've got some of the Rothwell attenuators and they work very well, so I thought I'd give the cables a shot too.
  6. #26
    Bigman80 Guest
    I've used some of the cable used in Rotwells "the river" cables myself so you won't go far wrong with these. Not a bad choice at all.
    Quote Originally Posted by MrRadish View Post
