Results 1 to 10 of 14
Thread: more record cleaning on the cheap :D
    I'm jamie.
    Default more record cleaning on the cheap :D
    A lovely day for cleaning records,here's what i do.
    first give them a soak in tepid water.I use a purpose made label protector i bought from the states
    Next a good scrub using a paint pad and triton x
    Next a good rinse under the tap! SHOCK! HORROR!
    Next 2 rinses in distilled water and each is sucked up using the upholstery attachment on a vax carpet cleaner,i stuck a moth record machine pad on the bottom of the tool.
    Lastly air dry,although they dont need it. shiny shiny!
    My System
    John Wood KT88 Amp.
    Paradise Phono Stage
    Sony TTS-8000 Turntable.
    PMAT-1010 MK6 Tonearm.
    Ortofon Cadenza Bronze
    Sony X555ES Cd Player
    Yamaha NS1000m Speakers
    I'm Allen.
    At what stage do you use the scouring pad
    I'm jamie.
    bugger ive left me secret weapon in shot!
    My System
    John Wood KT88 Amp.
    I'm Ian.
    Do you mind, that's my mirkin…….
    Turntable
    CD
    Network Player
    Cambridge NP30
    Amplifier
    Speakers
    Cables
    Headphones
    Bigman80 Guest
    Nice work there, interesting as I'm now looking at RCM due to the project one being sent back again!
    I'm jamie.
    dry in 1 revolution too
    My System
    John Wood KT88 Amp.
    Default more record cleaning on the cheap 😀
    No substitute for a moth or such.
    Hold their price quite well too. Worth investing in one if you can afford it Really does improve vinyl better than an expensive cart. Might be selling all mine to get a buggy. In time.
    I'm Ian.
    I clean my vinyl using the " Jamie " system and the results are easily as good as I got sending them off to be professionally washed and hoovered. Just takes a bit of time and effort.
    Turntable
    CD
    Network Player
    Cambridge NP30
    Amplifier
    Speakers
    Cables
    Headphones
    I'm jamie.
    Quote Originally Posted by Ian7633 View Post
    weren't they ultrasonically cleaned ian?
    My System
    John Wood KT88 Amp.
    I'm Ian.
    They were and in all honesty I was very pleased with the results but using your method yields just as good, and some of the records were in a right state.
    Turntable
    CD
    Network Player
    Cambridge NP30
    Amplifier
    Speakers
    Cables
    Headphones
