Hi,
If you look at my signature you can see my equipment
My problem is that I’m having real issues with earthing my newly acquired SME
I can’t figure out how to sort it, before when I had the original arm fitted there was a background noise on my Trichord anyway, sort of a slight puls, ebbing noise, which I intended to sort, however I bought the SME before I did
Now I’m getting a constant loud ticking sound as well, to the point that I can’t listen to vinyl
Does anyone have any ideas or suggestions for this problem?
Thanks
