Results 1 to 5 of 5
Thread: Pro-Ject RPM 1 Carbon in gloss red. New but needs cart. Cheap deal :)
    I'm Robert.
    Arrow Pro-Ject RPM 1 Carbon in gloss red. New but needs cart. Cheap deal :)
    Pro-Ject RPM 1 Carbon Turntable in red - new. Bargain. Needs cart.
    Never used, only taken out the box to view. Cartridge is damaged so needs a new one to work.
    As such, selling as a bargain. Change of plans forces sale.
    £240 incl U.K. post.
    The new RPM-1 Carbon design has been upgraded to significantly reduce resonance across the turntable. While maintaining the instantly recognisable shape, this turntable boasts improvements in the tonearm, bearing, and motor.
    The brand new tonearm is a carbon fibre/aluminium resin construct, made using special heat and pressure treatments. The result of this new design is a tonearm that is more solid and anti-resonant than ever before at this price, while maintaining a light weight. The arm is finished off with a pre-fitted Ortofon 2m Red cartridge and a new magnetic anti-skate mechanism. The improved counterweight also utilises TPE damping in the form of an anti-resonant ring around the fixing point.
    The completely decoupled motor is based upon the same design as the Xpression Carbon, powered by an AC generator that's connected to the new DC power supply. The inverted main bearing now utilises a ceramic ball, offering a more fluid and consistent platter rotation than ever before.
    Available in Red, White or Black high gloss finishes, the RPM-1 Carbon is a turntable package that offers truly phenomenal value for money.
    Key Features:
    •Precision belt drive using synchronous motor
    •Ultra-precision DC-driven AC generator motor power
    •Inverted platter bearing with ceramic ball
    •Platter made from MDF using felt mat
    •8,6” S-shaped tonearm made from carbon, aluminium, resin utilising special heat and pressure treatments
    •Magnetic anti-skating
    •Counterweight with TPE damping
    You could do with a better and bigger photo Robert.
    I'm Robert.
    OK, will do shortly
    lordmortlock Guest
    I'm Robert.
    Sold
