Audio Technica AT-OC9ML/II Moving Coil Cartridge
Never used - new
No longer needed so priced to move on.
£210 incl U.K. post.
The AT-OC9ML/II Dual Moving MicroCoil™ cartridge is a significant achievement in precision manufacturing, with tolerances held to mere thousandths of an inch. Stringent quality control assures that these tolerances, as well as performance criteria, are maintained by every AT-OC9ML/II cartridge.
In addition, the AT-OC9ML/II features:
Dual-coil system for maximum channel separation.
High-flux samarium cobalt magnet for improved electrical generation.
PCOCC coil windings for low-loss “transparent” signal transmission.
Gold-plated solid boron cantilever.
MicroLine™ stylus
Technical Specifications:
Type: Dual Moving Coil
Mounting: 1/2" centers
Frequency Response: 15 - 50,000Hz
Body Material: Aluminium
Channel Separation: 31dB (1kHz)
Output Channel Balance: 1.0dB (1kHz)
Output Voltage: 0.4mV (1kHz and 5cm/sec.)
Vertical Tracking Angle: 23°
Vertical Tracking Force Range: 1.25 - 1.75g (1.5g standard)
Stylus Shape: MicroLine™
Stylus Curvature Radius: MicroLinear™
Stylus Construction: Nude Square Shank
Cantilever: Gold-plated solid boron
Coil Impedance: 12Ω (1kHz)
Coil Inductance: 25µH (1kHz)
DC Resistance: 12Ω
Static Compliance: 35×10-6cm/dyne
Dynamic Compliance: 9×10-6cm/dyne (100Hz)
Recommended Load Impedance: Min 100Ω
Weight: 8.0g
Dimensions: 17.3 (H) x 16.8 (W) x 25.7 (L) mm
Replacement Stylus: When the stylus is to be replaced, replace the entire cartridge. Take the used cartridge to your Audio-Technica Authorised Service Centre. The new cartridge, or any other model which is desired among the line-up of MC cartridges sold by Audio-Technica, are available at the stylus replacement price.
Accessories Included: 1 non magnetic screw driver; 1 brush; 2 washers; 2 x 13.5 mm mounting screws; 2 x 18 mm mounting screws; 1 plastic protector
