Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
Thread: Pre amp matching
    Default Pre amp matching
    Yesterday I bought a glass house passive pre that I had owned previously.i also collected a trafomatic elegance 2 power amp (300B) in the hope of using them both together.
    The pre has to be wound around 3/4 of the way to get any sound and with the pot fully open I still only get a low to moderate level of volume.. No distortion or similar even with the pot at full vol.
    Is this just a matching issue? I heard the power amp working at the sellers using a naim all in one type thing as the pre.
    Is it just a case that this power amp needs an active type pre??
    I'm Phil.
    i was just pondering that question myself , having tried rather a lot of pre amps like you guys have too
    i have only heard of being only able to turn vol knob a few mm and its too loud
    https://www.pinkfishmedia.net/forum/...assive.215410/
    Eric Bibb
    Power amp is not sensitive enough for a passive, you will need an active pre or a buffer with gain betwixt the passive and the power amp.
    You haven't got anything I could try just to prove the Power amp have you Mart?
    I've a couple of integrated amps where the pre amp can be split from the power amp. A Harmon Kardon and an XTZ. Not world beating pre amp sections but will drive any power amp. You're welcome to have a borrow.
    Cheers Mart i only want to prove it's working ok. I'll drop you a Pm
    I think you need to take the source into account as well mate. If it has a low output then an active will be required, if it's powerful then a passive may be appropriate. This all ignores impedance matching. If it is a valve stage with unusually high output impedance it may be losing gain driving the passive (though realistically this is not very probable). What is your source driving the amps, and If you trust it why not connect it direct to the power amp and play some known quiet music to see how loud it is? For gawds sake don't choose anything noisy or you could do the speakers some mischief!
    Gain and output are not standardised across manufacturers so these compatibility issues seem rather too common.
    I'm using a chevron paradox dac but it was just as quiet using my old pioneer PDS9o5 CD player
    Ok, Chevron is off my radar but the Pioneer would be up to the task. Are you sure the tubes in the power amp are all sound?
    Slightly left field, but I have a very nice sounding Moth Series 30 active pre-amp that has high output and drives insensitive power amps very well. I have too many pre-amps and the Moth is not in use at the moment.
