Hi - the volume knob on my Marantz is playing up, with the sound cutting in and out as you turn it, with lots of crackling. Anyone know a solution and if not, know anyone good who can repair it? I live in Oxford.
Cheers
Nick
I'm Nick.
Cheers
Nick
Might need a clean, there's a thread on here about doing it. Use deoxit.
http://theartofsound.net/forum/showt...ghlight=Deoxit
You should be able to get a temporary fix with switch cleaner sprayed into the volume control. It does sound like the control could need replacing as it is at the stage of cutting out.
I could do it for you, I'm in the West Midlands, but near Dudley.
Cheers,
Alan
I'm Nick.
Thanks for the advice. So do I just pull out the plastic knob and squirt straight onto the metal spindle?
I'm Nigel.
Hello Nick,
Pm sent ref. contact in Oxford that could help you with this.
Nigel
